| Home Theater Design and Construction FlooringDiscuss Flooring in the Home Theater Installation and Systems forum; Flooring In the process of building my HT room, one of the biggest obstacles I'll be facing is the flooring. The ... |
| | #1 (Link) | |||
| Flooring In the process of building my HT room, one of the biggest obstacles I'll be facing is the flooring. The room is in the basement/garage area, and has been prone to flooding. We have talked to people about getting that fixed, but right now its not an option right now. A friend of mine gave me an option that I think I'm going to do. He recommended that I lay down pre-treated 2x4's every 15" then lay down some plywood on top of that. The question I'm wanting to ask is what should I lay down on top of that? I'm thinking some type of floor tile, nothing too too heavy though. Budget is a factor here if that helps. | |||
| | #2 (Link) | |||
| Re: Flooring How deep does the water get? If it's just water running across the floor, use Dri-Core. That's what it's meant for and also does a good job in isolating noise and cold. If it's more than that, I'd wait and get it fixed or you'll be rebuilding your theater in 2-3 years due to mold, mildew, rot, etc. Bryan | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| cork flooring | robk_11 | Home Theater Design and Construction | 4 | 03-03-07 06:24 PM |
