HT French Doors (and my Wife) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss HT French Doors (and my Wife) in the Home Theater Installation and Systems forum; HT French Doors (and my Wife) I'm finalizing my home theatre design, and running into my last design detail... The current HT room has a single ...
Old 02-05-08, 07:19 PM   #1 (Link)
New Member
Alias: interfx
User: #16508
Since: Feb 2008
interfx is offline
I'm finalizing my home theatre design, and running into my last design detail... The current HT room has a single door (solid) that comes into the existing HT room... (Perfect, no light in the window)
Now the issue, my wife wants me to install a dual, french door style (with windows in them) so the HT room looks more open and connected to the family room... (vs. disappearing into the HT room)
Anyone done frosted glass ones? Any other ideas out there with respect to doors heading into your home theatre room...
Thanks
Old 02-05-08, 07:22 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: HT French Doors (and my Wife)
Frosted won't keep light out - sorry. In addition, it's very very difficult to get french doors to close securely enough to not rattle when the sub get's humping.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 02-05-08, 07:26 PM   #3 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
Yep, doors are often the biggest problem in HTs for sound leakage, air sealing, etc. The recommended is to use as heavy a door as possible, with industrial sound-proof seals (not just those rubber strip things).
Any glass surface in an HT room could cause havok with reflected sound AND light...
View our home theatre project at the Wychwood website. Comments welcome!
Old 02-05-08, 08:02 PM   #4 (Link)
New Member
Alias: interfx
User: #16508
Since: Feb 2008
interfx is offline
Thanks this will help...
Also, any idea if the existnig 31" door will let typical theatre seating fit through it? or should I upgrade the door to a full 36" opening?
Thanks in advance, just found this forum (while another was down)...
Thanks
Old 02-06-08, 07:12 PM   #5 (Link)
New Member
Alias: Kaos
Loc: Upper Marlboro
User: #15568
Since: Jan 2008
tkaotic is offline
They make a good point on why not to use french doors. I am using french doors because of the visual appeal of it coming into the room. But also my doors are going to at the complete opposite end of the room from subwoofers and I also plan isolating the door from the floor. I think if you plan enough the problems of french doors can be overcome. But remeber im a newbie but i am in the middle of doing lots of research before the hardcore build within the next couple of weeks.
Old 02-07-08, 12:04 AM   #6 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
I have double glass doors about 2' from my subwoofer. They rattle like you wouldn't believe. Also, they are the source of some nasty acoustic problems. A glass door is far harder to treat for reflections (it's right behind my listening position) than a wall. I'd say you're bying trouble here... Tell your wife I said so!
My DIY build Status: Almost done.
My room thread
Old 02-07-08, 12:47 AM   #7 (Link)
Alias: Tom
User: #8593
Since: Apr 2007
YW84U is online now
interfx wrote: View Post
Thanks
I would strongly consider a 36" door if it's feasible - it would leave you with a lot more options down the road. My original entrance opening was 28" (boy, that's narrow), and ultimately I ended up having to sawzall it out and go 32" just to get my sofas in. I don't think they're coming back out without a little surgery, though .....glad I waited to order the door until near the end of the build!!
I believe that most theater seating (Berklines et al) require some assembly, so navigating them in through standard door widths shouldn't be an issue. I echo the sentiments about the french doors w/glass... they will be difficult to deal with in order to block light and prevent rattles. Sound control may also be a concern for both inside and outside of the room. I used a solid-core door with a full exterior neoprene weatherstrip frame - I've found it makes a significant difference in sound levels throughout the rest of the home. While it may be more aesthetically pleasing to have the 'open' look, it may be worth discussing whether loud sounds will have more of a negative impact on the family. There may well be a way to incorporate a single door and give it a more open feel by 'dressing up' the entryway to the theater - maybe with moldings, furniture, or paint colors on the family room side.
Cheers,
Old 02-08-08, 04:59 PM   #8 (Link)
New Member
Alias: interfx
User: #16508
Since: Feb 2008
interfx is offline
Thaks, all very good advice (and wife has read it now also)... We're sticking with a solid core door (36") as our main entrance...
Stay tuned... Finalizing the layout in the next weeks, before I spend my tax refund to get this started...
InterFX
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Top Boxes for my wife BoomieMCT DIY Speakers 8 12-09-07 12:54 AM
Wife Demands New Display -- Please Help! Otto Video Displays and Processors 37 08-02-07 08:09 AM
My newest project that drives my wife crazy! Mongrel714 Home Theater Equipment 0 06-19-07 10:52 PM
It looks much better with doors closed! bobgpsr Home Theater Gallery 1 03-16-07 12:43 AM
Samsung Blows the Doors off Moore’s Law for Flash Memory Wayde Home Theater, Audio and Video News 0 09-27-06 06:00 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
