Banggood.com Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! StereoList Shop Amazon! SVSound Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Chase Home Theater: Ushering a new generation of super charged home theater equipment. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Genelec: Active Speakers and Speaker Systems SpectraCal: Specializes in the tools and training necessary to achieve images representative of the content creator’s intent for viewing environments.
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Theater Design and Construction
Views: 3669 - Replies: 7
Old 02-22-08, 09:48 AM   #1
MatrixDweller's Avatar
Zip
Since: Jul 2007
Canada
My Photos
  MatrixDweller is offline
Speaker placement w/Projection Screen
I have some Klipsch RB81 bookshelves and a RC62 center and will be using a 92" projection screen. How should I place the speakers in relation to the screen for optimal results?
Some examples:
1) Mount the speakers with wall mounts, bookshelves to either side of the screen and center channel just below all firing parallel to the floor.
2) Use stands and keep all the tweeters on the same plane and in line with ear height.
3) Use stands or mounts for the bookshelves and have them centered on either side of the screen and tilted down so that the tweeters fire inline with ear height. Center would be below the screen either stand or wall mounted and angled slightly.
I know from past experiences with normal TVs and speakers that were too low it sounded like the movies were coming out of the floor rather than the screen. Any suggestions would be appreciated. Also the benefits/drawbacks personal experiences of speaker stands vs wall mounts would be nice.
Old 02-22-08, 10:19 AM   #2
HTS Senior Moderator
bpape's Avatar
Bryan Pape
Since: Sep 2006
Wildwood, MO (St. Louis)
My Photos
  bpape is offline
Re: Speaker placement w/Projection Screen
Keep the L and R somewhere between seated ear level and screen center.
Bryan
Bryan Pape
Lead Acoustician
GIK Acoustics
Old 02-22-08, 11:48 AM   #3
tonyvdb's Avatar
Tony
Since: Sep 2007
Edmonton, Alberta, Canada
My Photos
  tonyvdb is offline
This is how THX recommends you set up your speakers for optimal performance. HERE
Home theater:
Onkyo TXSR805, Yamaha YDP2006 EQ, Samson Servo 600 amp
EV Sentry 500 monitors, 4 Mission 762i's Surrounds, Klipsch RC-52 Centre, SVS PB13 Ultra sub,
Toshiba A30, Panasonic BD60, Harmony 1000, Nintendo Wii
Panasonic PT-AE4000 on a 120" 2,35:1 fixed screen
Two Channel system:
Sherwood/Newcastle R972, Mission 765's, A/D/S MS3u sub, Yamaha YDG2030EQ
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20
Sony KDL40EX500 LCD, HD-PVR
Old 02-24-08, 03:46 PM   #4
Zip
Since: Jul 2007
Canada
My Photos
tonyvdb wrote: View Post
The overhead shots don't really give a good idea on how to place them vertically. I would think logically you'd want them centered on the sides somewhat so that it would sound like it was coming out of the screen. I think I will play around a bit resting them on cinder blocks at varying heights.
Old 02-25-08, 08:11 PM   #5
tonyvdb's Avatar
Tony
Since: Sep 2007
My Photos
  tonyvdb is offline
You need to always keep the fronts at ear level when seated the sides and surrounds should be placed at head hight when standing and tilted down.
Home theater:
Two Channel system:
Old 03-09-08, 11:22 AM   #6
gullfo's Avatar
Glenn
Since: Nov 2006
Old Tappan, NJ
  gullfo is offline
in general, keep the speaker-to-listener vertical angle to 10° or less, although the side and rear speakers can typically be a bit higher because the bulk of program content comes from the front speakers.
Old 03-09-08, 02:46 PM   #7
Zip
Since: Jul 2007
Canada
My Photos
Would it be better to place them so that the tweeter is at the center of the screen height and then tilt them down so that they fire to the listener's ear? I have them set up now on temporary stands (http://www.hometheatershack.com/phot....php?file=1034) and resting on the stage. The tweeter are about ear level give or take a few inches and are inline with the center channel's high frequency driver. It sounds ok so far.
Old 03-09-08, 04:57 PM   #8
gullfo's Avatar
Glenn
Since: Nov 2006
Old Tappan, NJ
  gullfo is offline
usually there is an "acoustic" center on the speaker - somewhere between the high/low/mid frequency drivers and you can draw your line from there. that said, if the tweeter is in line with your ears, then you're probably just fine because after several feet, the dispersion on the high frequencies will likely mask any small differences in elevations (except if you, or the speakers, are sitting in locations were modes, SBIR, or other reflections cause anomalies in the response, or if you have highly directional speakers).
Glenn
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater Installation | Systems > Home Theater Design and Construction »
placement, screen, speaker, w or projection
Bookmark and Share
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2012, Home Theater Shack, LLC.
Search Engine Friendly URLs by vBSEO
