hey guys,
i have a small ht and my pj is located just behind my seating position in the sealing.
i would like to lower my noise floor and the pj is the villain, it might not be to bad, but i want it as silent as i possible can.
my pj is a jvc dila hd350. it has air intake on the front and has air exhaust on the side.
i would prefer to close the hush box completely from the ht. i can put intake and exhaust fans in the box or on wall in other room.
i have the option of making a vent or 2 to another room, but they will have to be pretty close together(max 60cm/2 feet part including pipes). im also limited to make straight pipes thought the wall so its no possible to get cold air from low position and to get the exhaust out up high. so bothe intake and exhaust have to be within 40cm/16" of the ceiling.
so questions :
1/ what fan? how much airflow do i need? max hole size is 15cm/6".
2/ do i need only fan on intake or both intake and exhaust?
3/ how much breathing room(thinking about size of box vs pj size) should i give the pj?
4/ is it nesecary to make an "exhaust" after the fan on intake and and exhaust side. or should i just go with one big box?
i hope some of you people with hush box experience can point me in the right direction
best regards
panduro
so questions :
best regards
panduro
