Need Expert Help for unique design - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Design and Construction
Discuss Need Expert Help for unique design in the Home Theater Installation and Systems forum; Need Expert Help for unique design We are trying to make a wall mounted media cabinet with doors that slide straight out to the sides... thereby ...
Old 04-07-08, 07:47 PM   #1 (Link)
New Member
Alias: Lexi Fleet
Loc: San Diego
User: #19320
Since: Apr 2008
Lexi Fleet is offline
We are trying to make a wall mounted media cabinet with doors that slide straight out to the sides... thereby sitting to either side of the tv box when the doors are open. We do NOT want them to retract inside the box. We are going to mount 3D art on the doors.
We don't know what kind of mechanism to use to slide the doors. Any ideas and suggestions would be most appreciated.
This photo gives an idea of what we want the doors to do.... thank you so very much for your time and expertise!
http://www.luxist.com/2007/08/15/mir...ma-tv-cabinet/
Old 04-08-08, 08:52 AM   #2 (Link)
rjb
New Member
Alias: RB
Loc: Washington, DC
User: #19172
Since: Apr 2008
rjb is offline
Re: Need Expert Help for unique design
Lexi,
I could not see the photo on the link. Do you want the art to be visible when the doors are closed? I am assuming so and in that case you will need to put the doors on tracks. I would recess the tracks on the doors and mount the slides to the cabinet. Make the doors are wide enough so that they cover the slides in both the open and closed position. You will have to mount a sturdy pair of slides on both the top and bottom of the door spaced far enough apart to support the art and the door. The other way to do it is to build the tracks into the cabinet and cover with molding. This will result in a very wide cabinet.
Old 04-08-08, 09:10 AM   #3 (Link)
New Member
Alias: Lexi Fleet
Loc: San Diego
User: #19320
Since: Apr 2008
Thanks so much for your reply. The frame is going to be a sturdy "box" that is mounted on the wall. The "doors" in front will house some three dimensional art. What I want is for the doors to just slide open straight out to the sides and stay there. I'm not sure why the link didn't work, but I'll try inserting a photo. Thanks again for any insights you might have. If not, here is a new link that might work better. http://www.dothell.com/media/08-20-0...asma_colla.jpg
Old 04-08-08, 05:28 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I'm using sliding doors to cover my window ...
I went to Lowes and got a pair of tracks for closet doors; I installed the track flush to the wall and the wheels on the doors ... now, I can just slide the doors to the side of the window when I want light in the room ...
There's some slides that can be mounted flush to the wood, they will be covered with door closed but whne you open them ... you will see the track (take a look here http://www.knapeandvogt.com/Heavy_Du...=products.1.22) ... you'll get the idea
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Design and Construction »
Similar Threads
Help with a Sub Design Please.. Wildcard26 DIY Subwoofers 25 09-16-07 11:19 AM
Design help. mgboy DIY Subwoofers 1 07-21-07 03:02 PM
Denon 2910 connection ?s - unique I think Methodical System Setup and Connection 8 12-21-06 04:28 PM
Somewhat unique acoustics questions crackyflipside Home Audio Acoustics 6 11-26-06 06:21 AM
This design look OK? garymck DIY Subwoofers 12 07-06-06 07:21 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
