I'm a newbie with some question! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Equipment
Discuss I'm a newbie with some question! in the Home Theater Installation and Systems forum; I'm a newbie with some question! Hello all, I'm pretty new to HT setup and I'm not sure how I need to go about doing what ...
Old 05-27-08, 01:40 PM   #1 (Link)
New Member
Alias: Pimp
User: #11144
Since: Aug 2007
eriktylermorgan is offline
Hello all,
I'm pretty new to HT setup and I'm not sure how I need to go about doing what I want to accomplish. So any help would be excellent. I have a fairly large basement. (approx. 1300 sq. ft.) In the one side with be the "Theater" with a panasonic projector and a 1000 watt surround sound with dvd player. On the other side of the basement I'm putting 6 to 8 in wall speakers and would like to put another receiver by the bar to run those speakers. My main question is can I hook the HT receiver up to this receiver when needed. (i.e. people are over for a party or gathering or whatever the case may be) Or is this not a possibility or is there an affordable way to run those other speakers off the HT system. Any help would be appreciated and I can't finish and drywall the basement until I have this solved.
Old 05-27-08, 04:58 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: I'm a newbie with some question!
Most receivers have some sort of tape or source out that you can use to send a line signal to your bar receiver. Is the main receiver capable of multi room output?
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 05-27-08, 10:22 PM   #3 (Link)
New Member
Alias: Pimp
User: #11144
Since: Aug 2007
No it does not have multi room capabilities. One of my friends said there may be "latency"(not sure if I spelled it right) issues. Not sure I totally understand what he's talking about and is this true? thanks
Old 05-27-08, 11:41 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
What receiver model Do you have???
If I understand you want to run the speakers at the bar only when not using the HT, Right???
Some receivers have A, B and A+B speaker selector ... you can use speaker A when using HT and speaker B for the bar area; or A+B to run all speakers
This doesn't mean you will be hearing two different sources ... the sound will be from same source.
Do this make sense??? ... also, this is assuming your receiver has the speaker selector option
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Equipment »
Similar Threads
Newbie question Bob_99 DIY Subwoofers - Infinite Baffle 3 12-21-07 12:51 PM
newbie question or two (help!) Home Team DIY Subwoofers 21 09-07-07 08:15 AM
Newbie in wall RL-s 15 question. reedwesd SoundSplinter 8 08-06-07 07:06 PM
5.1 vs 7.1 surround Newbie question MikeWard70 Home Theater System Recommendations 12 07-31-07 09:27 PM
Newbie question about 33-2050 mjhamre REW Forum 3 01-28-07 11:30 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
