Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater Installation | Systems > Home Theater Equipment
  Discuss My HT in the Home Theater Installation | Systems forum; My HT Speakers Front L/R -Diy active quad amped 4way using SEAS H1212 tweeter,SEAS CB17RCY/P midrange,SEAS P21REX woofer,dual AC10 10" woofers in ...
Views: 2365 - Replies: 4
Old 09-20-06, 11:07 PM   #1
Alias: Habs fan
Loc: Up here
User: #1415
  F1 fan is offline
My HT
Speakers
Front L/R-Diy active quad amped 4way using SEAS H1212 tweeter,SEAS CB17RCY/P midrange,SEAS P21REX woofer,dual AC10 10" woofers in sealed bass module.
Center channel- Diy active bi amped 2way with a SEAS H1397 tweeter and 2 x Vifa M17SG midwoofers.
Rear -JBL SP6 inwalls
LFE- 2 x 12" woofers in sealed boxes with ELF/EAS EQ.
Electronics
Front L/R-Tweeter amp -Bryston 2B LP
Midrange amp -Bryston 2B LP
Woofer amp - Bryston 3B
Bass module amp - Bryston PP120
Center channel -Tweeter amp -1/2 of Bryston 2B LP
Midbass amp -1/2 of Bryston 2B LP
LFE amp-2 x Hypex Ucd180 Class D modules.
Rear amp- Teac AX1000 Integrated amp.
Active crossovers Fronts -Bryston 10BLR for the mid-woofer crossover and custom DIY design for the mid- tweeter crossover.
Custom DIY designs are used for the center channel and subwoofer.
DVD player- Modified Pioneer DV563 .It also functions as the surround decoder for DolbyDigital ,DTS,DVD-A and SACD..
Preamp (front l/r)-DIY design using discrete Jfets/Mosfets and Sulzer regulators.
Outboard DAC - Custom unit using Crystal CS 8420 and CS43122 chips.
DVD recorder- Pioneer DVR220
HD Satelite reciever- Star Choice Motorola 505
Surround processor -Technics SH500-used for decoding surround from the sat dish only.
TV- Panasonic TH37PX60 37" Plasma.
Old 10-10-06, 12:44 PM   #2
jokers10
Inactive
Alias:
User: #
Posts: n/a
Re: My HT
That appears to be a pretty insane setup. Good luck on getting an LCD that can match the picture quality of your CRT. It seems like a never ending battle.
Old 10-10-06, 09:04 PM   #3
Alias: Habs fan
Loc: Up here
User: #1415
  F1 fan is offline
Re: My HT
jokers10 wrote: View Post
Yeh, my Wife would agree that all the pieces of electronics is insane
If I want to get into HD ,LCD is the most economical way for me to do it.
Old 11-04-07, 05:13 PM   #4
Alias: vince dallaire
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
  vince is offline
Re: My HT
That is in fact an awsome equipment setup. You are light years ahead of me, I'm just getting started in the seprates department I may take you up on the offer for the correct components for the BSC filter. First I have to finish the x-over and measure and see where I'm at... I just have about four hours of final wiring to do and I'm done with x-over. What did you think about compensating EQ wise? for baffle step? I am pruchasing a couple more DSP parametric EQ's. It is nice to have this control. After the learning curve was over using the Behringer DSP1124P, I think its a nice unit for the money, wish they would make some stuff like this for dedicated "home" use, without hum problems to worry about! I think when I build some DIY mains to start I will also go with sealed boxes instead of ported. Two 7 inchers and one 1" dome MTM array sealed, long as I can get a 3db down of 80Hz I would be happy. After I am done I will post my findings.
Cheers,
Vince
BTW I have a Panny1000u in a dedicated room, no windows, Da-lite 110" high power. Used to have the Da-matte material, I love this high power screen!!!!! no hot spoting at all, very bright, and off angle viewing not to bad either.
Old 11-04-07, 06:47 PM   #5
Alias: Habs fan
Loc: Up here
User: #1415
  F1 fan is offline
Re: My HT
vince wrote: View Post
Thanks
Certainly just give me a yell.
hummm I'm not sure that it could be done with the precision that can be achieved using the op amp solution.It would likely take several bands of EQ , lots of tweaking and accurate measurements would needed to verify that you are getting the intended results.
Very nice. I would love to have that combo for hockey and Nascar.
« Home Theater Shack > Home Theater Installation | Systems > Home Theater Equipment »
Bookmark and Share
Dish Network
