Toe equipment - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Equipment
Toe equipment
Discuss Toe equipment in the Home Theater Installation and Systems forum; Toe equipment My equipment has about settled down... Sanyo PLV60-HT (1368x768 widescreen LCD) Yamaha NS-777 mains Paradigm CC-350 center Polk R55i surrounds ...
Old 05-18-06, 09:43 AM   #1 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
  toecheese is offline
Toe equipment
  • Sanyo PLV60-HT (1368x768 widescreen LCD)
  • Yamaha NS-777 mains
  • Paradigm CC-350 center
  • Polk R55i surrounds
  • Polk RC60i rear surrounds
  • Pioneer VSXD814 receiver
  • Behringer DSP1124P BFD
  • Behringer EP2500 amp (for subwoofer)
  • FicarAudio Q18 drivers- customized for IB (2x in a custom IB subwoofer)
  • Philips DVP5960/37
  • Samsung OTA HDTV tuner
I also hook up a PC and Dreamcast occasionlly though the VGA input on the projector, but I'm still undecided what to do with those components.
I plan on building my own cables (more info on that later). I'd also like to get two more drivers for my subwoofer (sing out if you come across any).
Old 05-18-06, 11:10 AM   #2 (Link)
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: Toe equipment
Nice setup... I bet that Sanyo is the bomb huh?
I was reading elsewhere about your IB setup with that Behringer amp. Interesting... have you consider adding a couple of Tumults?
Massive and 66mm ptp excursion
Old 05-18-06, 03:26 PM   #3 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
Re: Toe equipment
Yes, I wanted those just for the cool factor- figure'd I put them in the ceiling and put in plexiglass just so I could look at those baskets!
Then the price factor took over
They don't recommend mixing subwoofers, so I'd have to go all the way- as it is, I'm already looking to complement my two Tempests with two more.
As far as the Sanyo- yeah, it was the bomb when it came out, for sure. And its specs are still impressive. I have no complaints, but when I was getting it, some people warned that it doesn't have DVI/HDMI, but it looks like recent trends will keep analog connections going for some time.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Equipment »
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
