My HT - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Equipment
My HT
Discuss My HT in the Home Theater Installation and Systems forum; My HT Speakers Front L/R -Diy active quad amped 4way using SEAS H1212 tweeter,SEAS CB17RCY/P midrange,SEAS P21REX woofer,dual AC10 10" woofers in ...
Old 09-20-06, 11:07 PM   #1 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
My HT
Speakers
Front L/R-Diy active quad amped 4way using SEAS H1212 tweeter,SEAS CB17RCY/P midrange,SEAS P21REX woofer,dual AC10 10" woofers in sealed bass module.
Center channel- Diy active bi amped 2way with a SEAS H1397 tweeter and 2 x Vifa M17SG midwoofers.
Rear -JBL SP6 inwalls
LFE- 2 x 12" woofers in sealed boxes with ELF/EAS EQ.
Electronics
Front L/R-Tweeter amp -Bryston 2B LP
Midrange amp -Bryston 2B LP
Woofer amp - Bryston 3B
Bass module amp - Bryston PP120
Center channel -Tweeter amp -1/2 of Bryston 2B LP
Midbass amp -1/2 of Bryston 2B LP
LFE amp-2 x Hypex Ucd180 Class D modules.
Rear amp- Teac AX1000 Integrated amp.
Active crossovers Fronts -Bryston 10BLR for the mid-woofer crossover and custom DIY design for the mid- tweeter crossover.
Custom DIY designs are used for the center channel and subwoofer.
DVD player- Modified Pioneer DV563 .It also functions as the surround decoder for DolbyDigital ,DTS,DVD-A and SACD..
Preamp (front l/r)-DIY design using discrete Jfets/Mosfets and Sulzer regulators.
Outboard DAC - Custom unit using Crystal CS 8420 and CS43122 chips.
DVD recorder- Pioneer DVR220
HD Satelite reciever- Star Choice Motorola 505
Surround processor -Technics SH500-used for decoding surround from the sat dish only.
TV- Panasonic TH37PX60 37" Plasma.
Old 10-10-06, 12:44 PM   #2 (Link)
Alias: jokers10
Loc: Altus, OK
User: #3011
Since: Oct 2006
jokers10 is offline
Re: My HT
That appears to be a pretty insane setup. Good luck on getting an LCD that can match the picture quality of your CRT. It seems like a never ending battle.
Old 10-10-06, 09:04 PM   #3 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Re: My HT
jokers10 wrote: View Post
Yeh, my Wife would agree that all the pieces of electronics is insane
If I want to get into HD ,LCD is the most economical way for me to do it.
Old 11-04-07, 05:13 PM   #4 (Link)
Alias: vince dallaire
Loc: Phoenix, AZ
User: #12578
Since: Oct 2007
vince is offline
Re: My HT
That is in fact an awsome equipment setup. You are light years ahead of me, I'm just getting started in the seprates department I may take you up on the offer for the correct components for the BSC filter. First I have to finish the x-over and measure and see where I'm at... I just have about four hours of final wiring to do and I'm done with x-over. What did you think about compensating EQ wise? for baffle step? I am pruchasing a couple more DSP parametric EQ's. It is nice to have this control. After the learning curve was over using the Behringer DSP1124P, I think its a nice unit for the money, wish they would make some stuff like this for dedicated "home" use, without hum problems to worry about! I think when I build some DIY mains to start I will also go with sealed boxes instead of ported. Two 7 inchers and one 1" dome MTM array sealed, long as I can get a 3db down of 80Hz I would be happy. After I am done I will post my findings.
Cheers,
Vince
BTW I have a Panny1000u in a dedicated room, no windows, Da-lite 110" high power. Used to have the Da-matte material, I love this high power screen!!!!! no hot spoting at all, very bright, and off angle viewing not to bad either.
Old 11-04-07, 06:47 PM   #5 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Re: My HT
vince wrote: View Post
Thanks
Certainly just give me a yell.
hummm I'm not sure that it could be done with the precision that can be achieved using the op amp solution.It would likely take several bands of EQ , lots of tweaking and accurate measurements would needed to verify that you are getting the intended results.
Very nice. I would love to have that combo for hockey and Nascar.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Equipment »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
