My modest system to this point.... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Equipment
Discuss My modest system to this point.... in the Home Theater Installation and Systems forum; My modest system to this point.... What I've got at this point in trying to piece the necessary components to build my system TV Olevia 232V ...
Old 01-17-08, 12:27 PM   #1 (Link)
Alias: Icon
Loc: Atlanta, GA
User: #15352
Since: Jan 2008
HomeTeam is offline
TV
Olevia 232V
DVD and Game
Toshiba HD-DVD A2
Sony Standard DVD (don't have the model number on me, but its an older one)
Nintendo Wii
EDIT 4/1- Sony PS3 40 GB
Speakers
Paradigm Atom (Black)
Other
Monoprice 3x1 HDMI Switcher
Last edited by HomeTeam; 04-01-08 at 10:22 PM. Reason: added recently purchased components
Old 01-17-08, 12:38 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: My modest system to this point....
You're definitely on your way! Do you have plans for a sub?
Old 01-17-08, 12:48 PM   #3 (Link)
Alias: Icon
Loc: Atlanta, GA
User: #15352
Since: Jan 2008
HomeTeam is offline
Yeah, I was planning on getting the Paradigm PDR-8. With my speakers, I'm pretty much going to follow what's recommended for the Atom Monitor System.
But that's going to wait as I'm focusing on my receiver next. I have my eye on a particular one, but I'm doing my research before jumping in and buying it because it does seem like there would be others that can do the same thing but with a better price.
Old 01-17-08, 01:22 PM   #4 (Link)
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
Mitch G is offline
I had an Atom/CC-170/PDR-8 system.
The first upgrade (within a year) was to the PDR-10.
But, then I went and upgraded that to an SVS PC+ about a year later.
So, the moral of this little story is don't necessarily box (pun intended) yourself in with the "recommended" Paradigm setup. In fact, much like the adage about buying a telescope, you should get the largest/best sub you can afford and fit in your room.
And, fwiw, I recently upgraded my mains from the Atoms to Ascend Acoustic Sierras.
That said, I really think the Atoms are one of those hidden jewels out there for the price. They still do a fine job as my surrounds.
Mitch
Old 01-18-08, 09:56 AM   #5 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Mike P. wrote: View Post
Or an AVR? I think I'd buy that first
Old 01-18-08, 01:22 PM   #6 (Link)
Alias: Icon
Loc: Atlanta, GA
User: #15352
Since: Jan 2008
HomeTeam is offline
eugovector wrote: View Post
I have my eye on the Onkyo TX-SR605. I'm wanting something that seems like it would be future proof and can run Dolby TrueHD and all the other current HD audio as well as video. And since it has 2 HDMI inputs it'll be there when I do get a Blu-Ray player (right now my eye is on the 40 GB PS3 but that could change as well).
But I'm still doing my research on that one so it could change, but right now my eye is on the Onkyo.
Old 01-18-08, 05:23 PM   #7 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is online now
HomeTeam wrote: View Post
I have my eye on the Onkyo TX-SR605 ... But I'm still doing my research on that one so it could change, but right now my eye is on the Onkyo.
What about a receiver with Pre-outs??? ... so you can add a separate amp for every speaker
Old 01-18-08, 10:27 PM   #8 (Link)
Alias: Icon
Loc: Atlanta, GA
User: #15352
Since: Jan 2008
HomeTeam is offline
salvasol wrote: View Post
Ok this one you're going to have to explain to me because I'm not understanding this one. I figure just connect the necessary speakers into the receiver.
Old 01-19-08, 08:03 AM   #9 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Salvasol is saying that you can further future proof by finding an AVR with preouts, so that if down the road you like the processing in your AVR, but wish it played louder/cleaner with inefficient speakers, you could just buy separate amps for each channel.
Pre-outs are nice to have, but I wouldn't spend more money on an AVR just for pre-outs if you don't see yourself using them.
Old 01-22-08, 04:56 PM   #10 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
Like Marshall said ... the pre-out is an option on receivers to be able to add an external amplifier to every speaker (you will get a better sound) but is not neccesary to have
You'll be okay if you get the Onkyo, here is a link to Amazon, and I think you can get it thru the Shack electronic store here at the forum, or you can check around for the best price (Amazon.com: Onkyo TX-SR605 7.1 Channel Home...Amazon.com: Onkyo TX-SR605 7.1 Channel Home... )
You may also consider this set of speakers, like I say before, they will sound better than the Coby
Amazon.com: Polk Audio RM6750 5.1 Channel Home...Amazon.com: Polk Audio RM6750 5.1 Channel Home...
Good Luck
Old 01-24-08, 04:11 AM   #11 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
I think that the Onkyo TX-SR605 is a very good choice as a start. I heard it and it offers so many features at this price that I find it to be a bargain.
And you can always sell it later on to buy a better one (more powerful?) when you get the cash.
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Equipment »
Similar Threads
New Home Theater groups from Berkline at the Market in High Point, NC RSH Home Theater Seating and Accessories 0 05-06-07 07:22 AM
Hello From Point Pleasant,NJ RSD2005 Welcome | Member Introduction 6 12-09-06 10:19 AM
Episode 20: Stay Alive / Point Break / Beavis & Butthead Do America Roger Movies | TV Shows | Hollywood 0 10-10-06 06:10 AM
Experience with various HT seating after attending Market in High Point NC RSH Home Theater Seating and Accessories 0 08-02-06 10:01 AM
Point of Attack drpaulng REW Forum 4 06-05-06 09:13 PM
Mach 5 Audio
