| Home Theater Gallery My dedicated roomDiscuss My dedicated room in the Home Theater Installation and Systems forum; My dedicated room First post, and my dedicated room.
Description at: http://www.klipschcorner.com/SystemP...play.aspx?Id=1
I am a horrific photographer:... |
| | #1 (Link) | |||
| My dedicated room First post, and my dedicated room. Description at: http://www.klipschcorner.com/SystemP...play.aspx?Id=1 I am a horrific photographer: ![]() ![]() ![]() ![]() | |||
| | #4 (Link) | |||
| Re: My dedicated room Gotta love Klipsch. I've got some. Not Cornwalls but still sound nice. You might want to put your camera on a tripod or rest it on something then tweak the aperature and/or shutter speed (exposure). Open the aperature up and descrease the shutter speed, turning the flash off, and you should get a nice picture. Since the shutter speed is slow if you are holding the camera you will get a blury picture because you can't help but move or tremble slightly. The flash will also tend to wash out the projection screen and cause anything shiny to gleam (like the leather on your sweet furniture). Increase the ISO setting also and you might remove some of the grain and blur. | |||
| | #6 (Link) | |||
| Re: My dedicated room not bad, next time you try to take pics of the screen, turn the flash off and set the camera on self timer then put it down on something solid. This will slow the shutter speed down. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| dedicated cd player recommendation? | enrique | HiFi Audio Components | 8 | 07-13-07 09:59 PM |
| Ideally, which room for dedicated HT? | brandonnash | Home Theater Design and Construction | 5 | 06-10-07 09:11 PM |
| The Shack is now on a dedicated server... | Sonnie | Forum Announcements | News | 0 | 11-25-06 09:38 PM |
| Dedicated HT PLanning-Need Input! | RyanJNielson | Home Theater Design and Construction | 7 | 04-27-06 08:33 PM |
