Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Gallery
Discuss My System in the Home Theater Installation and Systems forum; My System ***Scroll down to see new setup as of June 6, 2009*** About as much as I will get away with ...
Views: 5077 - Replies: 42
Old 09-19-08, 10:13 PM   #1
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is online now
About as much as I will get away with until I build a home. A 57" LCD upgrade is in the plans.
Old 09-20-08, 12:30 AM   #2
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
SteveCallas wrote: View Post
Looks good steve, i would like to do a similar thing with the centre matched to the mains.
And it seems you have every gaming system ever made!
Posted via Mobile Device
Old 09-20-08, 12:39 PM   #3
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: My System
Are those bass traps or subs in the corners?
Old 09-20-08, 03:23 PM   #4
Alias: thxgoon
thxgoon's Avatar
User: #6924
  thxgoon is offline
Re: My System
Looks like you took a lot of time setting that up with all the tilt angles and what not! Is that a Yamaha receiver?
Old 09-21-08, 01:33 AM   #5
Alias: Steve
User: #263
Re: My System
The big black tubes are my dual Avalanche 18 LLTs. The white things are absorption pannels and are used throughout the room, as seen in these extra pictures.
Yeah, I've got everything just right. I have zero plans for any audio upgrading after having completed the second subwoofer, everything sounds great. Watching movies and listening to music is a real treat.....a larger tv down the road would only make things better. Yes, I'm using a Yamaha HTR 5890.
Old 12-18-08, 09:52 PM   #6
Alias: Steve
User: #263
Re: My System
Well, what do we have here? A wider upper section of a tv stand? Hmm, what on earth could that be for?
Old 12-19-08, 08:12 AM   #7
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: My System
Just a wild guess but I'd say a 57" LCD would fit on that stand. But I could be wrong!
We're all in this together!
Members DIY Subwoofer Database
Old 12-22-08, 10:45 AM   #8
Alias: Mark
Loc: Northern Virginia
User: #30445
Since: Dec 2008
  oldmp3 is offline
Re: My System
Steve,
Very nice setup. Could you post a list of your components or did I miss that? The vertical center is a nice choice - what brand speakers, and component racks?
Thanks.
Old 12-22-08, 11:29 AM   #9
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: My System
Hmmm... that looks strikingly similar to the Samsung stand I have that will hold a 57" - 67" display.
Old 12-22-08, 10:36 PM   #10
Alias: Steve
User: #263
Re: My System
Well guys, the original plan was a 57" LCD, the Honeywell Altura 57" to be exact, but this thing just doesn't seem to be coming to fruition. The tv was supposed to launch last Jan, then last April, then last July, then last October, and now who knows. The website doesn't even answer my emails, I guess it's vaporware.
When it didn't launch last October, I had to move to plan B. The Samsung 650/750 models got rave reviews from every technical website based on objective measurements as well as high subjective praise. After viewing it several times for myself, it definitely looks like a winner. So I think I will be getting the ln52a650. The 42" 1080p Westinghouse will replace my 21" computer monitor - that should be pretty sweet.
The stand is actually a Mitsubishi stand for their DLP models, but it's the only stand out of literally hundreds out there that fit my needs of holding enough weight, being wide enough without being too wide, and having a look that will easily allow me to match it when I build a lower stand to stack it on. All that and the price was ridiculously low because the DLP model in question is discontinued
Thanks. I was a bit hesitant to try the vertical center speaker idea, but now I could never go back, much more seamless sound.
Here's my equipment list.
The racks were some Walmart brand, Home Essentials or something, nothing special. You'll notice the tv stand is actually two stands, as I had to build the mini one on the bottom to get the tv the correct height. I'll be doing the same thing with the new stand. I'll be keeping the audio racks....although the grey bars won't match anymore.....I may have to paint them black
Old 02-18-09, 02:09 PM   #11
Alias: Adam
Loc: Palatine, IL
User: #31101
Since: Dec 2008
  geniusadam is offline
Re: My System
is that an N64, a nintendo, and a sega genesis that i see? SEXY!!!
Old 03-07-09, 02:30 PM   #12
Alias: Steve
User: #263
Re: My System
Don't forget the Atari 7800 Master System, Gamecube, and Xbox 360. Sadly I've had almost zero time to play with any of them for the past year. Early retirement is the only path to happiness.
Old 05-09-09, 12:10 PM   #13
Alias: Steve
User: #263
Re: My System
Finally made up my mind and just placed my order. The new display that will be taking the place of my Westinghouse LVM-42W2 is the Samsung LN52B750. The specs and pq are great, and the new design with TOC grey as opposed to red should go well with my existing audio racks.
Should be here within a couple weeks
Old 05-09-09, 08:57 PM   #14
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
  ironglen is online now
Re: My System
Good for you Steve! You'll appreciate the larger picture- I recently bought a 50" and although it is 720p, I'm glad I bought a 50" vs a 42" 1080p. Watching my first sports on it right now-nba basketball looks great! Enjoy!
Old 06-06-09, 12:24 PM   #15
Alias: Steve
User: #263
Re: My System
Alright, here it is. Two new tv stands - I built the one on bottom. New display, a Samsung LN52B750 LCD. A new arrangement of my equipment which does a much, much better job of hiding the hundreds of cables. A Belkin surge protector which you can't see has been added, as well as some Monoprice cable upgrades.
This tv is pretty slick - to appreciate the size difference, use one of the receivers on the upper rack of the audio towers for scale.
I'm very happy
Old 06-06-09, 12:44 PM   #16
Owner
  Sonnie is offline
Re: My System
Lookin' good...
Old 06-06-09, 01:03 PM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Re: My System
Boy those subs are not easy to hide, The lows must really hit you when watching moves in that room.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-06-09, 01:19 PM   #18
Alias: Steve
User: #263
Re: My System
Thanks Sonnie!
Who wants to hide them? The room would be really plain and empty looking without them. And yes, they are quite capable
Next upgrade would logically be a blue ray player, but I'm not exactly itching for one by any means. Maybe when a good quality player comes along for ~$200 and the movies can be had for less than $10 used I'll jump. I'm willing to spend money on HT as can be deduced, but there has to be some sense of value for me to make a purchase, and blue ray currently doesn't exude any sense of value to me.
Old 06-06-09, 01:28 PM   #19
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My System
BluRay has issues, HD DVD was far better and much cheaper for quality gear. My Samsung still has issues playing some BluRay movies usually twice during a movie the video drops out for about 5 seconds, its really annoying.
Home theater:
Two Channel system:
My Webpage
Old 06-06-09, 02:00 PM   #20
Alias: Glen
Loc: West Texas
User: #34808
Since: Mar 2009
Re: My System
Very nice. I too am waiting on blu ray-for a multitude of reasons, but primarily cost! The upgrade(s) to my entire system have my jaw dropping all the time- this with regular dvd's, so no hurry for blu ray.
Old 06-06-09, 04:40 PM   #21
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: My System
Nice setup.....specially those silos on the sides
Old 06-19-09, 09:48 PM   #22
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
  Fabricator is offline
Re: My System
BIG sounds, small video. and no blu-ray ?! i am frugal, and i do not watch anything but blu-rays. $200 panasonic bd35 and netflix. doesn't get much cheaper than that. yeah BD has problems, but what doesn't.
anyway
your setup looks pretty nice.
Old 06-20-09, 01:55 PM   #23
Alias: Steve
User: #263
Re: My System
Sure it's no 120" screen, but it is 52" with a seating distance of 6.5', giving me a perfect 1.5 viewing distance ratio. When it comes to PQ, this set is in the upper tier.
dvd, hd-dvd
Blue Ray still needs to mature with a final set of specifications and disc prices need to come down. Used prices are still high because not nearly enough people are buying Blue Ray discs - they won't until prices come down, so it's a never-ending cycle.
Old 06-20-09, 03:40 PM   #24
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
Re: My System
Your system is very nice and those subs are fantastic. I have been lucky so far with my BD player, Samsung bdp-1500, it has the original firmware that it came with and has played everything I have put into it so far. It would look nice with your new TV.
Old 06-20-09, 07:05 PM   #25
Alias: Steve
User: #263
Re: My System
You guys are cranking up the peer pressure Maybe if the rumored PS3 $100 price drop pans out I'll come on board - with it I know I can always download the latest updates, and the loading time is supposed to be pretty fast. Disc prices are still the killer. One blue ray movie for $15-25 or 4-5 dvds for the same cost?
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Gallery »
system
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
