| Home Theater Gallery My HT set-up Discuss My HT set-up in the Home Theater Installation | Systems forum; My HT set-up I have a small room but I think I did alright with the space I had...... One thing I should ... |
Views: 1098 - Replies: 2
| My HT set-up I have a small room but I think I did alright with the space I had...... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() One thing I should do is get a bigger center to match up better with the B52's, any sggestion would be great. | ||||
| | #2 | ||||
| Re: My HT set-up If you can fit four seats across the room, then it's not that small, unless you're projecting across the room! Why two projectors? It looks like you've got some good gear and quite a lot of it in that room.. ![]() With timber all round, do you get much slap echo? Looks like a nice set up.. ![]() Prof.. Home Theatre...the never ending story! | ||||
| | #3 | |||||
| Re: My HT set-up Quote:
