| Home Theater Gallery Cedar Creek CinemaDiscuss Cedar Creek Cinema in the Home Theater Installation and Systems forum; Cedar Creek Cinema My build threads are in my sig links... those are the only links I have. Very very time consuming to ... |
Views: 5654 - Replies: 90
| | #51 | ||||
| Re: Cedar Creek Cinema My build threads are in my sig links... those are the only links I have. Very very time consuming to say the least, but rewarding too. | ||||
| | #52 | |||||
| Re: Cedar Creek Cinema Quote:
I like the look of it and the teeth rattling well I get that each time I travel on Bournemouth buses lots of low end bass vibrating all for a £3.00 all day ticket. ![]() 70mm was regarded as the Rolls Royce of picture and sound in its day. | |||||
| | #53 | |||||
| Re: Cedar Creek Cinema Just curious, Sonnie, how does the "EQ all the subs as one" thing work as far as linear response (or a reasonable facsimile thereof) at the various seats? Quote:
![]() Regards, Wayne | |||||
| | #54 | |||||
Scenario: Sub #1 has an +8dB peak @50Hz at the listening position. Sub #2 has an +8dB peak @50Hz at the listening position. Total peak at listening position @50Hz is +16dB. Sonnie applies a single -16dB cut and all is well. Would it have been better to apply a more reasonable -8db cut @50 Hz to both subs? brucek | |||||
| | #55 | ||||
| Re: Cedar Creek Cinema If sub 1 and sub 2 both have an 8db peak around 50hz, assuming no cancellations between them, the summed response would be an 8db peak around 50hz, not 16db. | ||||
| | #56 | ||||
| Re: Cedar Creek Cinema Yeah, that's what I was thinking, too. All things being equal, the second sub merely increases gain, across the board. Where's Sonnie? ![]() Regards, Wayne | ||||
| | #57 | |||||
Do acoustic signals not cancel and reinforce? Is signal reinforcement not how we enjoy extra headroom by adding a second sub, allowing the volume of each to be reduced? brucek | |||||
| | #58 | |||||
| Re: Cedar Creek Cinema Sorry guys... Angie and I were on a road trip yesterday to pick up yet another set of speakers. ![]() Wayne... the "we" stuff is mostly pointing to the design and finish of the room, however, Angie has spent more time in this room since it was built than she did all total in the other room. Still yet... "we" might as well be me and my imaginary friend. ![]() I have tried the equalization for all the seats and I do not care for it. I do not know if it is psychological because I can see the huge differences in the measured responses or if I really notice a difference, but I do not like it. I can equalize for the main listening position only... running three Audyssey measurements from that seat and from that seat it looks good. The other seats really do not look or sound any better or worse than they do when I use averaging and measure multiple seating locations... BUT at least I get one position, the main one, looking and sounding good. As far as the eq'ing all subs as one... I do not know the technical aspects of it, but I do know it works regardless of the location of the subs. I also know that any time I have tried (and I have tried many times) to equalize two subs independently, that while the individual responses have looked very good, once they are combined, the overall response looks awful. It has never... and I emphatically repeat "NEVER!" worked when I have tried to equalize subs independently for an overall smooth combined response. Quite frankly, I do not recall anyone ever succeeding at doing so... and it does not make sense that it can be done either. Quote:
| | #59 | |||||
If one sub is +8db at 50hz and the other -8db at 50hz, then yes, assuming no new room effects from placement of the second sub, they would cancel each other out and you would be flat at 50hz. The magnitude of the "flat" FR at 50hz would still be 0-6db higher though. | |||||
| | #60 | |||||
As an example, if I introduce two +8dB filters at 50Hz into an equalizer, the result will be absolute +16dB at 50Hz. That's a doubling of the single +8dB level, which is relative +6dB higher (20 log 16/8). brucek | |||||
| | #61 | ||||
| Re: Cedar Creek Cinema The EQ will boost the input signal by 8db twice - that's different than taking two subs with the same FR and playing them at the same time. | ||||
| | #62 | ||||||
If I have two signals in a room playing at +75 dBSPL, then the resultant SPL level is +81.02 dBSPL (pressure result is double = +6.02dB higher). Math is 20 log [10^(SPL1/20) + 10^(SPL2/20)]. And, if I have two signal peaks @50Hz in a room of +8 dBSPL, then the resultant peaks SPL level is +14.02 dBSPL (result is double = +6.02dB higher). Math is the same 20 log [10^(SPL1/20) + 10^(SPL2/20)]. So both increase by 6dB. brucek | ||||||
| | #63 | ||||||
![]() Quote:
Regards, Wayne | ||||||
| | #64 | ||||
| Re: Cedar Creek Cinema Sonnie, Just read this thread. Sweet looking HT. Wow. If I ever get to Alabama I need to stop by. Ron Carlton Dallas, Texas Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo BDP-83, Toshiba HD-A2, Belkin Pure AV PF60, Behringer DSP1124P Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Oppo DV-981HD, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro | ||||
| | #65 | |||||
![]() brucek | |||||
| | #66 | |||||||
Ideal to the discussion, I have a honkin’ peak at ~42 Hz.Here’s a graph I took today. The blue trace is both drivers running (no EQ). The red trace is one driver only. As you can see, the only thing that changes running both is overall gain. I suppose you could say the peak is “worse,” but its relation to the rest of the curve is the same. ![]() Regards, Wayne | |||||||
| | #68 | ||||||
| Re: Cedar Creek Cinema So - how 'bout it, Sonnie? Quote:
| | #69 | |||||||
![]() Quote:
Ahhh... and yes... more speakers. I swapped out my ML Spires for ML Prodigy's... I like the sound of the old style ML's better than I do the new style. | |||||||
| | #70 | ||||
| Re: Cedar Creek Cinema New pics... ![]() ![]() ![]() ![]() ![]() ![]() ![]() | ||||
| | #71 | ||||
| Re: Cedar Creek Cinema Sonnie, You never cease to amaze me. That is just the nicest theater setup I have seen Now if only I had the money to get mine to look even half that good. My wife wants me to do something with it but it all takes so much cash to get it there. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #72 | ||||
| Re: Cedar Creek Cinema Thanks Tony! You know it's only money... ![]() | ||||
| | #74 | ||||
| Re: Cedar Creek Cinema I don't even notice them. My eyes are always on the screen. No one else has complained either, not that they would. ![]() | ||||
| | #75 | |||||
![]() Another question, if you don’t mind: Some say that adding additional subs “evens out” response. Others say adding additional subs degrades response. Don’t recall if they meant at the sweet spot or for all the other seats as well, but which have you found to be the case? Regards, Wayne | |||||
