Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Gallery
My bonus room/ HT
Discuss My bonus room/ HT in the Home Theater Installation and Systems forum; My bonus room/ HT This is my computer-equipment-DVD Rack. It's flush in to the wall. The equipment rack is accessible from the back (attic) ...
Views: 6242 - Replies: 26
Old 10-25-06, 08:56 AM   #1
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is online now
My bonus room/ HT
I'm still working on it, hope to finish soon.
Old 10-25-06, 11:31 AM   #2
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: DIY
Nice work as usual... do you stand up to use your computer?
Old 10-25-06, 08:24 PM   #3
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Sonnie wrote: View Post
No!
I have a chair, the keyboard is on a shelf that slides out and is only like 2" higher then a normal desk.
Old 10-25-06, 09:47 PM   #4
Alias: Steve
Steve Williamson's Avatar
Loc: Gold Coast Australia
User: #496
  Steve Williamson is offline
Re: DIY
Looks great, the two cabinets on the sides look perfect for my equipment rack, any comments on how you made them? I will have access from the back of the cabinets too.
Old 10-25-06, 11:28 PM   #5
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Steve Williamson wrote: View Post
Thanks!!
The cabinet for the equipment is 18 W x 42 H x 20 D this are inside dimensions (1/2" wood MDF), the shelf's in between are 17" deep that way the hot air between the components can scape and have some room for all the cables, at the top of the back wall there is a 4" fan blowing the hot air out in to the attic, its a 120 volt fan hook to the receiver ac out, this way comes on when the receiver is on. I cut all the pieces and pre drill all the holes prime with Killz and used semi flat black paint, after that put the box together with screws, no glue, that way they can be taken apart in case I change the equipment. The holes on the out side panels are little bit bigger then the screws and you have to pre drill small holes in the panels(shelf's) were the screws are going in, if not the wood will split.
For the back I cut 2 panels, I screw the first one and measured 2" from the out side in then cut the inside piece that way I haded a frame to screw the other piece. The front I built a 2 1/2" frame did not use screws only wood glue.
Before I cut the sheetrock move some electrical wires out of the way then build the frame for the cabinet after that was done cut the sheetrock with a hand saw.
The DVD cabinet is 18 W x 42 H x 6 1/2 D on this one I glued all the panels.
If you don't understand let me know I will post in Spanish
I had some pics but I can't find them, I going to look for them if I find them I will post them.
I hope this will help you!!
Old 10-26-06, 01:21 AM   #6
Alias: Steve
User: #496
Re: DIY
I hope mine turns out like those, thanks for the guidelines. PS, what is the front frame made of, is that 1/2" MDF, does the 1/2" MDF stay straight when used as shelves for heavy amps etc?
Old 10-26-06, 08:55 AM   #7
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
They are 1/2 and my shelves are straight, you can use 5/8 if you want, it just going to make it heavier. The corners are cut at 45.
I don't have any big amps, the biggest thing is my receiver.
If you are using a big amp the best place will be the bottom.
Old 12-11-06, 02:09 PM   #8
garcianc2003
Inactive
Alias:
User: #
Posts: n/a
Re: DIY
awesome
Old 12-11-06, 08:42 PM   #9
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Getting there.......for now
This is like a never ending story
The color in the room is darker then the pictures.
Old 12-25-08, 03:04 PM   #10
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Re: DIY
Looks fabulous Rodny! What kind of screen do you have there?
mech
Old 12-25-08, 06:46 PM   #11
Alias: Pinhead
User: #30763
Since: Dec 2008
  Pinhead-227 is offline
Re: DIY
PERFECT. Absolutely stunning.
Edit:
Since you're upstairs (next to the attic) I assume you had to do quite a bit of work to the floor (ceiling of the lower level) to keep it quiet downstairs. How much sound proofing have you done?
Old 12-26-08, 05:50 PM   #12
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Re: DIY
Very nice looking theatre Rodny..Well done..
I bet those IB's rock the house!!
Prof..
Home Theatre...the never ending story!
Old 01-13-09, 03:25 AM   #13
Alias: Don
BattlesD's Avatar
User: #32019
Since: Jan 2009
  BattlesD is offline
Re: DIY
now you see it, now you don't........
Old 01-13-09, 06:02 AM   #14
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: DIY
I love the color scheme. What are the floor area dimensions?
We're all in this together!
Members DIY Subwoofer Database
Old 01-13-09, 09:46 AM   #15
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
Re: DIY
Fantastic, I love the desiegns you made with the acoustic foam. very artistic.
Old 01-23-09, 05:06 PM   #16
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Mike P. wrote: View Post
Thanks!!
The front is 12' W by 24' long plus the side of the computer its about 17'w, its a L shape room.
Old 01-23-09, 05:10 PM   #17
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Prof. wrote: View Post
No IBs its a LLT design, 35 cft with 2 RLP 15's tune to 11hz one on each side of the room
Thanks!!
Old 01-23-09, 05:14 PM   #18
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
mechman wrote: View Post
mech
Thanks!!
The screen is a Da-lite model c 100"
Old 01-23-09, 06:12 PM   #19
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Pinhead-227 wrote: View Post
Edit:
no sound proof ,the room its over the garage so its not to bad, it was pretty bad when I had the IB's, that was one of my main reasons why I went with the boxes (LLT)
Thanks!
Old 02-15-09, 06:39 PM   #20
New Member
Alias: bkeech
User: #34043
Since: Feb 2009
  bkeech is offline
Re: DIY
That cabinet rack is great. Could you describe the back in more detail? I also want to build a similar cabinet that will be accessable on the back side.
Thanks,
Bryan
Old 02-16-09, 10:14 AM   #21
Alias: QBall
QBall's Avatar
User: #33122
Since: Jan 2009
  QBall is offline
Re: DIY
Very interesting look. Good if you have limited space.
Old 02-16-09, 09:12 PM   #22
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
bkeech wrote: View Post
Thanks,
Bryan
I just build the cabinet and cut the back panel about 2" from the edge, that way I can screw another piece from the back, one thing I need to change is the way the back piece attaches, I'm going to put some hinges and some kind of lock instead of screws
Old 02-18-09, 10:14 PM   #23
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
I found some pics of the build................
Name:  Copy of IMG_1337.JPG
Name:  Copy of IMG_1339.JPG
Name:  Copy of IMG_1342.JPG
Old 03-21-09, 02:17 AM   #24
Alias: Rodny
Loc: Millbrook AL
User: #158
Re: DIY
Trying different colors
I used eggshell on the ceiling but I think is to reflective so I'm going to painted with some flat, just the ceiling part!
Old 06-21-09, 05:52 AM   #25
Alias: max
Loc: AUSTRILIA
User: #22495
Since: Jun 2008
  danielmichael is offline
Re: DIY
Hi Rodny do you have a ht build thread on here? I saw 1 a wile ago with how u did the subs ,but i cant find it can u send me a link please regards dan
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Gallery »
