| Home Theater Gallery My roomDiscuss My room in the Home Theater Installation and Systems forum; My room Here are a few pics of my room.... |
| | #7 (Link) | |||
| | Re: My room Very nicely done...Those seats give it a real theatre look.. My only concern would be that seat right against the side wall...Whoever gets that seat is going to get one sided surround side.. Good idea painting the doors black..I would find anything white between seating and screen, very distracting.. What size and type of screen are you using? | |||
| | #8 (Link) | ||||
| Re: My room Quote:
Yes you probably are correct on the one sided surround but since I don't sit there I myself don't care about that spot much - hard room to work with. The screen is DIY 92" Diag. It is painted with a flat gray from behr(Silverscreen). | ||||
| | #10 (Link) | |||
| Re: My room The seats came from a local guy - he was working on doing a room in his basement and decided against it. I went and checked them out and cleaned them up, painted the base pieces black and installed them. The room is very oddly shaped - the width of the very front is like 9', the width where the seats are is like 12-13'. The length of the room was like 25' I want to say. The screen is MDF mounted on the wall, painted with 3 coats of paint, with spray painted 3 1/4" trim. | |||
| | #16 (Link) | |||
| Re: My room This is just my opinion, please don't get mad ..... If you can move the surround on the right side (near the poster) at the same level as the front, maybe it will give you a better surround effect ..... I think is to far off the other back sorround. ![]() | |||
| | #17 (Link) | ||||
| | Re: My room Quote:
Looking at the plan, it looks like the surrounds need to be moved forward to just behind the front row..That would then get that right surround out of the corner.. | ||||
| | #18 (Link) | ||||
| Re: My room Quote:
| | #19 (Link) | |||
| Re: My room Not sure which direction you are going with that - This works best with the odd shaped room I have. I tried many different locations - If I move the rears closer towards the center it just didn't sound right to my ears... Do you mean like this? | |||
| | #22 (Link) | ||||
| | Re: My room Quote:
Even so, I would still try and move them a little forward to get that right speaker out from the corner.. Di-poles should have at least 18" of clear space forward and back, to prevent reflections.. My Tri-poles are just within that limit ,due to an archway just forward of the speakers, and if I move them a little closer to the archway, I don't get a smooth transition of sound from front to the back wall.. | ||||
