My home theater project - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Theater Gallery
Discuss My home theater project in the Home Theater Installation and Systems forum; My home theater project Hi everyone, I just bought a house and started setting up my home theater in the basement. I decided that ...
Old 09-05-07, 11:41 AM   #1 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is online now
I decided that going the paint on screen was my best option and that way I could get the 96" diagonal size I wanted without breaking the bank. Buying the exspencive screen paint was a no go so I did some research including looking at the info on this site and found it to be great. I went with the Bahr "silver screen" paint option. and am thrilled with the results.
This is how it looked at the beginning of the project just after moving in. I built a wall at the back for the projection screen that I would paint on.
Half way done.
Almost finished.
The ceiling is made up of 40 4'x4' "tectum" panels that are used to prevent sound transfer and the right wall is drywall on the lower half and carpet underlay on the top half with insulation behind the entire wall. The basement theater is 15' wide and 35' long and has a 9' ceiling.
I set up my Audio control 3rd octave eq's and ran a pink noise test signal using a 3rd octave spectrum annaliser with mic. and found the room to be very flat in response with just some very minor dips an peaks in the eq's after setting them up properly to flatten the rooms sound.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 09-05-07, 03:42 PM   #2 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is online now
Re: My home theater project
Nice room
What are you planning to do with the doorway in the left side of the screen??? ...
I had the same in my room, but what I did is to paint it black so it match with the front wall and the light won't distract ....
Good luck .... hopefully you will start enjoying your HT soon ....
Old 09-05-07, 03:55 PM   #3 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
salvasol wrote: View Post
Nice room
Thanks,
It will be a door that when closed will be flush with the wall and wont be noticeable.
Nintendo Wii
Old 09-05-07, 06:42 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
tonyvdb wrote: View Post
..It will be a door that when closed will be flush with the wall and wont be noticeable.
Nice !!!
What kind of carpet are you using??? .... something special???
I have something similar to your room ... but in my case, the accoustic carpet is at the bottom and drywall on the top ... I'm also using four 2' x 2' panels ...
I think the sound is good ... I'm planning someday to use REW to measure it ....but .. .. when ....
Old 09-06-07, 09:21 AM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
I'm using low pile carpet with two layers of underlay on the floor so its good and soft. On the wall I'm using black foam underlay available at The Home Depot, its a bit pricy at $35 for a 10' roll but looks really good as you can see in the photo.
Nintendo Wii
Old 09-06-07, 05:16 PM   #6 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
.... On the wall I'm using black foam underlay available at The Home Depot, its a bit pricy at $35 for a 10' roll but looks really good as you can see in the photo.
Did you purchased the carpet already???? .... if not, take a look in this place
http://www.acousticalsolutions.com/p...nt_fabrics.asp
this is what I got for my HT ... is not cheap, but I liked because is not like the regular carpet ..
Old 09-07-07, 09:22 AM   #7 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Yes, I have already bought it but the link you sent looks like nice stuff. May have to get some later down the road. Thanks.
Nintendo Wii
Old 09-13-07, 08:13 AM   #8 (Link)
Alias: fred33
Loc: Rochester, NY
User: #11295
Since: Sep 2007
Fred33 is offline
Very good size room. Looks like you have done a lot of work. I like the double TV setup, one for gaming and the other screen for movies. Very cool.
Old 11-09-07, 03:16 AM   #9 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
It looks like it is coming along really well. Have you made anymore progress?
Do post more pictures when you complete your room.
Old 12-09-07, 03:11 PM   #10 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Well after a little break from renovating I have gotten my theater room to this point.
I still need to install some new track lighting and some recesed lighting as well as build a pony wall behind the two sofas but it sounds and looks farly good in my opinion.
The area behind the listening position is where we have the computers and play area for the kids.
There is a area the same size on the other side of the left wall that has been split up into a storage room, bedroom, full bathroom and laundry room.
No I can relax for the Christmas season
Nintendo Wii
Old 12-11-07, 01:11 PM   #11 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
It looks like its movie time! The painted door definitely helps. Enjoy.
« Home Theater Shack > Home Theater Installation and Systems > Home Theater Gallery »
Similar Threads
Need advice for Home Theater / Project Studio tmwalke1 Home Audio Acoustics 17 11-25-07 08:51 PM
Calif Home Theater denschultze Home Theater Design and Construction 2 07-09-07 02:41 PM
My little Home Theater JRace Home Theater Equipment 2 06-06-07 04:42 PM
7 speaker home theater DIY project with active crossover...would love discussion cobyh DIY Speakers 38 04-18-07 12:35 AM
Home Theater vs Movie Theater Roger Home Theater, Audio and Video News 0 05-09-06 07:45 PM
Mach 5 Audio
