Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Set Projector Upside Down
Discuss Set Projector Upside Down in the Home Theater | Audio and Video forum; Set Projector Upside Down I have a new setup where the projector is now sat on top of a 7 foot high room divider ...
Views: 898 - Replies: 3
Old 04-09-08, 05:07 PM   #1
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
  BleedingStar is offline
I have a new setup where the projector is now sat on top of a 7 foot high room divider type piece. Now, projectors are meant to either be set table hight right side up or ceiling mounted upside down. So without angling it extremely downward and have to use the keystone A TON, then the image is projected with the bottom of the screen starting at about 6 feet. The projector is an Acer XD1170D, and it has no vents on the top of the projector. I am wondering if there would be any problem at all in laying the projector upside down on the surface.
Old 04-09-08, 05:17 PM   #2
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: Set Projector Upside Down
BleedingStar wrote: View Post
Hi!
I am not sure I understand very well what you mean, but if I understand correctly you mean the projector will be upside down and lying on its top (where generally the controls are). You then propably mean something like what is in below picture.
If this is the case, just make sure to put it on something soft (I used soft foam) not to scratch its enclosure, and there shouldn't be a problem. You have to make sure the projector can turn the picture upside down from the menu though (check for Front/Ceiling configuration).
Hope this helps!
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-09-08, 05:27 PM   #3
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
yes that is exactly what I was meaning. Didn't think it would be too much of an issue, but i figured i'd check.
Old 04-09-08, 05:32 PM   #4
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
I had this "standby" business projector in this configuration for about 500 hours with no problems
ASME AI
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
