Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! RAM Electronics: Audio, Video, Home Theater and Computer Cables. PacParts: Replacement parts & accessories from the most recognized manufacturers in the Consumer Electronics Industry! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices Fi Audio: Infinitely amazing balanced high end musicality designed drivers! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Elite Screens offers the finest in affordable projection screens. Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Go Back   Home Theater Forum - Home Theater Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Home Theater Projectors
Plasma or projector?  Discuss Plasma or projector? in the Home Theater | Audio | Video forum; Plasma or projector? Hi, I am new to the forum and I would like to make myself a nice home theater set up. ...
Views: 810 - Replies: 18
Old 04-13-08, 10:44 PM   #1
Plg6067
Inactive
Alias:
User: #
Posts: n/a
Hi, I am new to the forum and I would like to make myself a nice home theater set up. The question is: plasma or projector?
Budget: Under $5000
If I got a plasma it would have to be 58 to 60 inches.
I would like to have a very clear, bright picture even when there is some light in the room, can I get that with a projector?
What are your thoughts? Any specific models?
Thanks
Old 04-13-08, 10:51 PM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is online now
Re: Plasma or projector?
You need light control to use a projector effectively. If you cannot control the light virtually completely, get the PDP. The real question is, what do you mean by "some light?"
...the soulshine, it's better than sunshine. It's better than moonshine. It's sure better than rain.
Old 04-13-08, 10:56 PM   #3
Plg6067
Inactive
Alias:
User: #
Posts: n/a
lcaillo wrote: View Post
Just maybe a lamp or something so it is not totally dark. I would not mind having no lights for movies, but I might have a light on when playing video games.(I forgot to mention that in the first post sorry)
Thanks for the quick reply
Old 04-13-08, 11:07 PM   #4
lcaillo's Avatar
User: #328
If you are willing to design very controlled lighting, you could easily use a projector. I would budget for quality lighting that you can control and for painting the room in dark, neutral colors, particularly the ceiling and the end with the projector. Even if it meant getting a less expensive projector. Do your self a favor and also budget a calibration by a professional. I would take something like a Mits 4900 with proper room design and calibrated over units several times the price in rooms with the wrong lighting and paint, uncalibrated. No contest.
Old 04-13-08, 11:13 PM   #5
Plg6067
Inactive
Alias:
User: #
Posts: n/a
Alrighty, thank you. That sounds good to me
Old 04-14-08, 02:58 AM   #6
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
I would also recommend that you go for a projector if you have a room large enough to use it.
As Leonard correctly pointed out, light control is very important when using a screen with low gain. And this is also valid for plasma TVs.
Otherwise, you could take a look at screens with high gain, like the one XScreen manufactures (www.xscreen.com). I have no idea of how much they costs (probably nor cheap)but you will get a top-of-the-line picture, even with day light in your room...
Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha
Old 04-14-08, 04:36 AM   #7
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Xscreen is expensive. A 80 inch screen is $2000 and a 100 inch screen is $2800.
Old 04-14-08, 07:15 AM   #8
lcaillo's Avatar
User: #328
High gain screens are always going to have hot spots. Stick with lower gain in general, or pay the $$ for more projector.
Old 04-14-08, 01:45 PM   #9
Plg6067
Inactive
Alias:
User: #
Posts: n/a
Mike P. wrote: View Post
Wow, I didn't even realize screens cost that much, I guess I won't be getting a high gain
Thanks for the info!
Old 04-15-08, 01:06 AM   #10
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
Xscreen screens, like most high gain screens, are specials: you can actually use them without much light control in your room. Not so many people buy them, I think that's why they are so expensive.
Low gain (<1.2) screens are much cheaper. Many good brands and models to choose from. If you're going for a projector solution then I recommend that you buy a very good screen (white or light gray, according to your room, projector and preferences).
But these low-gain screens are probably 3 or 4 times cheaper than the high-gain ones.
« Home Theater Shack > Home Theater | Audio | Video > Home Theater Projectors »
Bookmark and Share
Dish Network
