Set Projector Upside Down - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss Set Projector Upside Down in the Home Theater | Audio and Video forum; Set Projector Upside Down I have a new setup where the projector is now sat on top of a 7 foot high room divider ...
Discount Merchant
Old 04-09-08, 04:07 PM   #1 (Link)
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
BleedingStar is offline
I have a new setup where the projector is now sat on top of a 7 foot high room divider type piece. Now, projectors are meant to either be set table hight right side up or ceiling mounted upside down. So without angling it extremely downward and have to use the keystone A TON, then the image is projected with the bottom of the screen starting at about 6 feet. The projector is an Acer XD1170D, and it has no vents on the top of the projector. I am wondering if there would be any problem at all in laying the projector upside down on the surface.
2- 58" King Sound Prince Electrostat Loudspeakers
2- Infinity Audio PS210 Powered Subs to got with Electrostats
Jensen Center (soon to be replaced by: 1- Definitive Audio CLR2300 Center Channel
4- Technic SB-T100 (surrounds)
3- JL 10" Subs
Kenwood VR-6070 THX Receiver --- Denon AV600 ---- Technic SU-Z900
Acer XD1170 Projecter --- 120" Screen
Old 04-09-08, 04:17 PM   #2 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Re: Set Projector Upside Down
BleedingStar wrote: View Post
Hi!
I am not sure I understand very well what you mean, but if I understand correctly you mean the projector will be upside down and lying on its top (where generally the controls are). You then propably mean something like what is in below picture.
If this is the case, just make sure to put it on something soft (I used soft foam) not to scratch its enclosure, and there shouldn't be a problem. You have to make sure the projector can turn the picture upside down from the menu though (check for Front/Ceiling configuration).
Hope this helps!
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-09-08, 04:27 PM   #3 (Link)
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
yes that is exactly what I was meaning. Didn't think it would be too much of an issue, but i figured i'd check.
3- JL 10" Subs
Old 04-09-08, 04:32 PM   #4 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
I had this "standby" business projector in this configuration for about 500 hours with no problems
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
What to set my screen at okron Forum Help | Suggestions 1 01-22-08 08:28 AM
PB12-Plus/2 set-up ?? oil99 SVSound 8 11-01-07 04:55 PM
Anyone able to walk me through this set-up? E-A-G-L-E-S System Setup and Connection 5 10-03-07 02:16 PM
ECM8000-how do I set it up? rcarlton SPL Meters | Mic's | Calibration | Sound Cards 20 04-14-07 12:24 PM
Newb set up bigbang REW Forum 4 03-14-07 06:54 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
