| Home Theater Projectors HDMI issues with Infocus IN76Discuss HDMI issues with Infocus IN76 in the Home Theater | Audio and Video forum; HDMI issues with Infocus IN76 I have a problem with my Infocus IN76 projector not seeing any signal sent to it via HDMI. Initially I ... |
| | #1 (Link) | |||
| I have a problem with my Infocus IN76 projector not seeing any signal sent to it via HDMI. Initially I had the projector hooked up to a PS3 directly via HDMI and had no problems. I have just purchased the new Onkyo 606 amp however, so instead of the HDMI connection going directly to the projector it now passes through the amp. This is where the problems began! With this set up I was getting no signal through to the projector. Thinking the amp was to blame I went back to the original configuration of the PS3 connected directly to the projector and to my suprise I still obtained no signal. When HDMI is selected the screen goes black for a minute before returning to the red Infocus start up screen. I have tried all the possible resets on the PS3 and used a number of different HDMI cables but I still get no picture. The projector is still working fine via the component imputs! Please help before I pull all my hair out!!!! | |||
| | #2 (Link) | |||
| Re: HDMI issues with Infocus IN76 Welcome to the shack Bob! I am so sorry to read about your projector HDMI issue. You know that you should first turn it on and then the PS3, otherwise there might be some handshake issues. Re-Check the HDMI output IS enabled on the PS3. Re-do the PS3 setup and check again for one last time. Let the receiver out of the loop for now. If you still have issues, your unit might need servicing... Let us know what you find after making sure PS3 is putting out through HDMI.... And don't pull your hair out, it may be only a small issue that could be easily solved or repaired ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #3 (Link) | |||
| Re: HDMI issues with Infocus IN76 So Bob, did it work? Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #4 (Link) | |||
| Re: HDMI issues with Infocus IN76 Hey Bob, I am also the owner of an IN76, and had the same issue with my Sony DVD upconverting player. For the life of me I could not get the HDMI to do the handshake. Thats when I found this little tidbit in their manual... HDMI DDC: turns the EDID extension on and off. Some graphic cards cannot recognize the projector’s EDID. By default, the HDMI EDID extension is on (checkbox is checked) and the M1-DA EDID extension is off (checkbox unchecked). Change these settings if you have trouble using HDMI or DVI sources. You'll find it in the menu under Service - HDMI DDC. I had to turn mine off to get things working. Hope this helps, and buy their extended warranty! I had my projector for a year and eleven months when it died on me two weeks ago. There is a fuse problem with that projector, so just a head's up. Simple fix under warranty, but likely expensive if not. I just got in under the wire, and I am purchasing the extended warranty shortly. ![]() | |||
| | #5 (Link) | |||
| Re: HDMI issues with Infocus IN76 Thanks guys for all your help. Unfortunatly I am still having no joy. It looks like I will have to ship it back to Infocus for a service. I will post when I find out the problem. | |||
| | #6 (Link) | |||
| Re: HDMI issues with Infocus IN76 I had some handshake issues with another PJ and I had to unplug the HDMI from the back of the amp and plug it back in after everything else was powered up. It is a pain but it might work for you system the same way. | |||
| Thread Tools | |
Similar Threads | ||||
| infocus litepro 220 | ford10000 | Manufacturers Service and Support | 1 | 08-03-07 05:49 AM |
| InFocus | lcaillo | Manufacturer and Vendor Reference Information | 0 | 05-14-07 07:36 PM |
| HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? | geekwithfamily | Home Theater, Audio and Video News | 2 | 02-27-07 11:11 AM |
| Infocus 16 X 9 screen today only $30 | chasw98 | Projector Screens | DIY Screens | 0 | 09-22-06 04:28 AM |
| InFocus IN76 Video Projector Review | Wayde | Home Theater, Audio and Video News | 0 | 08-14-06 02:50 PM |
