Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Optoma HD65
Discuss Optoma HD65 in the Home Theater | Audio and Video forum; Optoma HD65 Does anyone have an Optoma HD65? I am deciding between the HD65 or the Sharp 510? Any suggestions would be ...
Views: 1947 - Replies: 22
Old 07-10-08, 05:23 PM   #1
Alias: matt
Loc: Highland Village
User: #22523
Since: Jun 2008
  49erfaithful is offline
Optoma HD65
Does anyone have an Optoma HD65? I am deciding between the HD65 or the Sharp 510? Any suggestions would be a help. New to the projector world.
Old 07-14-08, 09:09 AM   #2
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Optoma HD65
I'll give you a free "bump" to the top, but sadly I don't have any experience with these projectors.
Any reasons why you are limiting yourself to these two? Lumens, budget, have access to a great deal, brand preference, etc.?
There are a lot of great projectors out there between 1k and 3k right now. I just installed a Panasonic (1080p, forget the model) and I have a Sanyo Z4 and both are fantastic deals with great pictures.
Old 08-07-08, 08:54 AM   #3
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is offline
Re: Optoma HD65
Matt...did you ever decide on anything?
Old 08-07-08, 10:15 AM   #4
Alias: matt
User: #22523
Since: Jun 2008
Re: Optoma HD65
I purchased the Optoma HD65., and I am amazed by the picture quality. I was surprised when I hooked it up to my PS3 and it does 1080P. In all the documents I read about the projector nothing said it could do 1080P. Also I turned a "bonus room" with three windows (33"x 59") with blinds on them and the project works great during the day.
I would recommend this project to a friend. A 1080P DLP Projector for under $900. I will post pictures of the converted home theater later.
Matt
Old 08-07-08, 12:26 PM   #5
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
  chas is offline
Re: Optoma HD65
Thanks for the update...Looking forward to the pics!
Actually a 720P projector that downconverts the 1080P material...correct?
Old 08-24-08, 09:18 PM   #6
sudo4re
Inactive
Alias:
User: #
Posts: n/a
Re: Optoma HD65
Yes, I just got this pj and was amazed by how bright and detail this little thing can project. It's a 720P pj so it down converts anything higher than 720P and displays it as such. I would think your image will improve slightly if you switch your source to the pj's native resolution so it does not have to do any down converting. Just my .02.
Old 08-31-08, 08:54 PM   #7
Alias: marcosreg
Loc: Florianópolis,Brazil
User: #24460
Since: Aug 2008
  marcosreg is offline
Re: Optoma HD65
The HD65 is an amazing projector.
I am very happy with it.
Marcos
Old 09-05-08, 05:13 AM   #8
Alias: kris
Loc: India
User: #5275
Since: Jan 2007
  Rajesh is offline
Re: Optoma HD65
The optoma HD-65 is a native 720p projector . It can't deliver greater resolutions beyond its capability . What you see on the right corner of the screen is nothing but the input signal information from the PS-3. Any projector will do that.
If you hook up a HD-80 optoma you will be able to tell the difference yourself. You would find at least 100% more quality given the simple fact that the source and the display had same resolution.
regards
Rajesh
Old 09-05-08, 03:29 PM   #9
Alias: rburnett
User: #25264
Since: Sep 2008
  rburnett is offline
Re: Optoma HD65
I recently purchased this projector and I am very happy with it.. Great price.. there are reviews of it all over the internet.
Old 12-15-08, 01:04 PM   #10
Alias: mpw460
User: #30197
Since: Dec 2008
  mpw460 is offline
Re: Optoma HD65
I've had the HD65 for about 10 days now. One word: Awesome. I bought it online for $750 (lamp extra for $200). Best money I've ever spent.
Old 12-15-08, 01:11 PM   #11
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Optoma HD65
Excellent. Glad you like your purchase. And welcome to the Shack!
Old 12-15-08, 05:39 PM   #12
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Optoma HD65
Good to hear you're both happy with the projector..
The HD65 is also on my wish list at the moment..
Prof..
Home Theatre...the never ending story!
Old 12-16-08, 10:07 AM   #13
Alias: mpw460
User: #30197
Since: Dec 2008
  mpw460 is offline
Re: Optoma HD65
I just saw the HD65 online for $549 (excluding lamp)!! If you are considering it, that's an out & out steal. The picture is absolutely amazing.
Old 12-16-08, 05:22 PM   #14
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Optoma HD65
The CHEAPEST price here at the moment is $1700.00!! AUD.
Prof..
Old 02-05-09, 08:18 AM   #15
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
Re: Optoma HD65
i have owned the HD65 for almost a year and it is a wonderful projector.
i have just encountered my first problem with it. the bulb has blown after about 200hrs of use
optoma have advised me that they will inspect the unit for faults but it looks like i am going to have to buy a new bulb.
what i am guilty of is recurrent usage over small periods due to my testing in the projector screen forum.
i'll keep you guys informed on what happens.
Old 02-05-09, 10:50 AM   #16
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
Re: Optoma HD65
Hi Custy, I bought the HD 72 about a year or so ago and the bulb went after 300hrs. I called and they told me the same thing as they told you but when I got the PJ back it did the exact same thing and then I was told it needed a bulb. I was upset that the bulb only lasted such a short time and I could not get any satisfaction out of the CS rep I talked to. I asked to speak to the boss and after a ten minute conversation about it really being unreasonable to have a bulb blow so fast. Well it was worth it because he replaced the bulb for free and apologised for the problem. He charged me for a new bulb on my CC and after I sent the bad bulb back he gave me the credit back on the card. You should give it a shot because you might get it replaced like I did.
Old 02-05-09, 12:29 PM   #17
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
Re: Optoma HD65
thanks TC - i have not spoken to them yet about the inadequate life of the bulb.
but if they do refuse me one when they check it i will ask to speak to the manager as you have done.
Old 02-25-09, 01:39 PM   #18
Shack Moderator
Alias: custy
custard's Avatar
Loc: walsall, uk
User: #22494
Since: Jun 2008
  custard is offline
Re: Optoma HD65
just an update,
after two weeks of waiting since my projector was sent to optoma without any response, i decided to call them.
they told me that the lamp and lamp driver had been replaced under warranty repair and i should be receiving it in about a week.
Old 05-12-09, 10:54 PM   #19
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Optoma HD65
Anyone else have premature lamp failure..or any other problems?
I'm considering buying one from a Canadian seller on Ebay..
Very reliable from all accounts, but not covered here with any warranty..
Prof..
Old 05-13-09, 09:46 AM   #20
Alias: rburnett
User: #25264
Since: Sep 2008
  rburnett is offline
Re: Optoma HD65
I've been running mine for ~8 months or so with use of ~20 hrs per week with no issues. I bought mine through Amazon. I still love it... xbox360 COD WAW is what I've been playing a lot.
Old 05-13-09, 07:09 PM   #21
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Optoma HD65
Thanks...that's good to hear..
It seems that lot of guys in the UK are experiencing premature lamp failure, so maybe it's just the HD65's over there...
Prof..
Old 07-02-09, 02:05 AM   #22
Alias: Tiny
MonsterMaddness's Avatar
Loc: Tuscaloosa, Alabama
User: #19096
Since: Apr 2008
  MonsterMaddness is offline
Re: Optoma HD65
I have an Optoma HD 70 that I bought off amazon two years ago and have had no problems what so ever. I have a friend that had a Hitachi (I forget what model) but it broke and when he took it to a service center, they said some kind of board split and it would be more expensive to fix then to just buy a new one. Now he's saving his money for an Optoma HD 80.
Old 07-02-09, 07:51 PM   #23
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Optoma HD65
Well I solved the problem with the possible premature lamp failure..
When I bought my HD65 I also bought a 3 year worldwide lamp insurance policy that covers me for 2 replacement lamp within that time period..
Prof..
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
