Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Problems with Boxlight projector
Discuss Problems with Boxlight projector in the Home Theater | Audio and Video forum; Problems with Boxlight projector Hey All, I have a Boxlight CP-12t projector that I'm having problems with. Chassis no. MT6-CP-12t00 The projector will turn ...
Views: 300 - Replies: 1
Old 10-11-08, 10:19 PM   #1
New Member
Alias: frankie
Loc: oklahoma
User: #24294
Since: Aug 2008
  fldivall is offline
Question Problems with Boxlight projector
Hey All,
The projector will turn on for approx. 5-10min and then shut itself off. I've cleaned the filter with no change. Could it be the lamp going bad? Any suggestions?
Frankie
Old 10-12-08, 08:08 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Problems with Boxlight projector
The lamp is most likely.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
boxlight, problems, projector
