Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Panasonic pt-ax100u flashing under higher resolution!
Discuss Panasonic pt-ax100u flashing under higher resolution! in the Home Theater | Audio and Video forum; Panasonic pt-ax100u flashing under higher resolution! I just picked up a panasonic ax100u and hooked it up to my dish network VIP 222 with a HDMI ...
Views: 427 - Replies: 4
Old 10-19-08, 11:50 AM   #1
Alias: Adam
Loc: Kelso, WA
User: #27027
Since: Oct 2008
  akgolfpro is offline
I just picked up a panasonic ax100u and hooked it up to my dish network VIP 222 with a HDMI cord and it workes perfect! When I change the output of the receiver to anything higher than 480i or p the projector stars flashing on and off? 720p and 1080I causes it to flash! any ideas!
Old 10-19-08, 12:27 PM   #2
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Panasonic pt-ax100u flashing under higher resolution!
definitely sounds like a sync issue.
Do you have the problem with other sources? DVD player?
What about component instead of HDMI?
Good luck.
Old 10-21-08, 01:25 PM   #3
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
I have that problem with my Scientific Atlanta DH8300 box. I can't use HDMI in anything above 480i, it flashes on and off. It works fine with component. I think it's related to a firmware problem.
That may not be your problem though. It could be your HDMI cable. When you up the resolution you're upping the data transfer rate. Is your HDMI cable long?
Try swapping HDMI cables.
Old 10-22-08, 04:09 PM   #4
Alias: Adam
Loc: Kelso, WA
User: #27027
Since: Oct 2008
Componet is working fine, at 1080I! HDMI is 25FT.
Old 10-23-08, 07:33 PM   #5
Alias: Zip
Loc: Canada
User: #10408
Since: Jul 2007
It is possible that it's the cable. I'm not saying that it is, but it's possible. Flickering can come from a bad HDMI signal.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
flashing, higher, panasonic, pt-ax100u, resolution!
