Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Replacement Bulb... HELP!
Discuss Replacement Bulb... HELP! in the Home Theater | Audio and Video forum; Replacement Bulb... HELP! Hello everyone I thought this would be a great place to start to get a possible answer. I have a ...
Views: 387 - Replies: 1
Old 10-24-08, 08:41 PM   #1
jamesflint1980
Inactive
Alias:
User: #
Posts: n/a
Hello everyone I thought this would be a great place to start to get a possible answer. I have a Mitsubishi HC1500. I bought this bad boy last year with the all mighty tax return. Well I get some solid use out of atleast 8 hours a day. Well with a 2000 hour bulb I figured I'd be replacing this bulb once a year around tax return time no biggie. Well now I get the message on every time I turn it on saying "Bulb approaching shut down. Replace bulb soon." Well it still works but I want to get a replacement as soon as possible.
SO my question to the experienced community is can I simply buy a replacement BULB (cheaper) or do I have to dish out the big bucks and buy the whole LAMP setup that includes a new housing for the bulb... It seems pretty dumb to spend 250.00+ to get a bulb and a new housing when I can buy the bulb alone for 150.00 and simply put it in the old housing... Am I right in understanding this or is one of those things the projector companies made difficult for the masses in order to make an extra buck.
IF I can simply replace the bulb alone does anyone know what bulb I need to get, like a part number and any special instructions, like do I need to do anything crazy like saudering? Sorry to be such a cheap noob but I was prepared to spend a tax return to replace the bulb never thought it would reach burnout in a mere 7 months... Thanks again.
Old 10-25-08, 09:37 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Replacement Bulb... HELP!
Just get the raw lamp, but make sure that it is the identical OEM lamp, not a generic replacement. Do not buy it off of ebay. There are lots of reputable dealers as alternatives.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
bulb..., help!, replacement
