| Home Theater Projectors upgrade to Epson 6100..any others I should look at?Discuss upgrade to Epson 6100..any others I should look at? in the Home Theater | Audio and Video forum; upgrade to Epson 6100..any others I should look at? I have a 720p Projector now (Panasonic AE100U) and like alot of what the Epson says (18000.1 contrast, 4000 bulb ... |
Views: 1192 - Replies: 9
| upgrade to Epson 6100..any others I should look at? I have a 720p Projector now (Panasonic AE100U) and like alot of what the Epson says (18000.1 contrast, 4000 bulb life, close lumen value I am currently seeing and 10 memory settings) and its under $2000. What other models should I consider? The contrast is really important to me and 1800 lumens while not really telling the story should keep me in same ball park as the Panasonics 2000 output spec, I never had to run Pana out of Economy mode and thats important for bulb life, it also says bulb life is 4000 hrs. I ran the Pana in Normal mode which is bright but still in ECO mode for sports, but movies were fine in Cinema settings......again thats eco mode and longer bulb life. Thanks for any ideas. | ||||
| | #2 | ||||
| Re: upgrade to Epson 6100..any others I should look at? Hello Superchad! The 6100 should be a great improvment over your current projector for sure. From my experience with the UB, It should be a bright projector and contrast ratio should be much better, not to mention sharpness... I suggest you also have a look at the Panasonic AE 3000 which might be a slightly more expensive but a very good competitor. ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #4 | ||||
| Re: upgrade to Epson 6100..any others I should look at? Jeff, Being an Epson dealer is not the best argument BTW. Some might think you're biased... ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #5 | |||||
| Re: upgrade to Epson 6100..any others I should look at? Quote:
Why don't you type a review about the Epson 6100? We'll be waiting for it.ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #6 | ||||
| Re: upgrade to Epson 6100..any others I should look at? I am responding to a couple of responses. First, I will provide a review of the 6100 as soon as we install one. We mostly sell the Pro projectors. Second, if there was any problem with an Epson projector I would be the first to say. These forums are closely monitored by manufacturers and for the most part are full of good information. Since I am not hear to sell anything, why would I be biased? We sell their products because of the quality and performance. The only issue I have had is with the 7500UB and a Marantz SR6003. The OSD and GUI is distorted over HDMI. We spent several hours with Marantz and have determined that it resides with the AFC of the Epson projector. We have forwarded that info to Epson and they are working on it. Also, the 7500UB shipped without discrete IR power commands. Within days that was fixed. | ||||
| | #7 | ||||
| Re: upgrade to Epson 6100..any others I should look at? Fair enough! We'll be waiting for the review ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #8 | ||||
| Re: upgrade to Epson 6100..any others I should look at? What is the best size screen to use w/the epson 6100 and the 1080ub? | ||||
| | #9 | ||||
| Re: upgrade to Epson 6100..any others I should look at? There is not a black or white answer to this question. It really depends on so many factors such as throw distance, screen size, ambient light.... ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #10 | ||||
| Re: upgrade to Epson 6100..any others I should look at? Did you ever end up with a 6100? I saw that BB has them on sale this week for $1600, has me wondering myself if it's worth selling my epson TW700/ 810(720p) and forking over the extra $$$ My Tw700 has been almost too good - I love the picture quality, brightness, flexibility, response time on games etc... The only reason for me to upgrade would be to go to 1080p - Jack | ||||
