| Home Theater Projectors Just got a PJ551Discuss Just got a PJ551 in the Home Theater | Audio and Video forum; Just got a PJ551 so my buddy just gave me his pj551...he hadnt used it for a few months so when i turned it ... |
| | #1 (Link) | |||
| Just got a PJ551 so my buddy just gave me his pj551...he hadnt used it for a few months so when i turned it on it turned on perfectly fine...but the temp and light buttons are flashing...what do i do?? | |||
| | #4 (Link) | |||
| Re: Just got a PJ551 yea it projects the image fine....my friend said the bulb was changed somewhat recently but he didnt know how to turn the flashing lights off..i also noticed as far as tempurature goes it did seem to be running alittle hot.. | |||
| | #5 (Link) | |||
| | Re: Just got a PJ551 Is the fan running? If not, then the fan could be out and causing the temp to run higher than normal. The light for the bulb reset is probably in the service menu or possibly in the user menu. You may have to try to get a hold of a service manual, or call a service center for the product and see if you can find the code to get into the service menu. | |||
