Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Size screen for a Mitsubishi HC1500?
Discuss Size screen for a Mitsubishi HC1500? in the Home Theater | Audio and Video forum; Size screen for a Mitsubishi HC1500? I have a Mitsubishi HC1500 projector and was wondering how big of a screen I can go with while still ...
Views: 358 - Replies: 4
Old 04-18-09, 09:51 PM   #1
Alias: Cameron
User: #33698
Since: Feb 2009
  06'Goat is offline
I have a Mitsubishi HC1500 projector and was wondering how big of a screen I can go with while still having a good picture. I have a 120" right now and the picture is great but want to go bigger. My farthest couch is 25' from the screen and nearest is about 18'.... the projector can be as far as 25' as well so no problem there... its at 17' with the 120" screen. Could i go with a 150" screen do you think?
Old 04-19-09, 07:35 PM   #2
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Re: Size screen for a Mitsubishi HC1500?
I would personally find that size screen image too dull..
With your current 120" screen, you have approx. 17fL at the screen..
If you go to a 150" screen, that drops to 11fL..well below the recommended minimum value of 16fL..
You would also probably have to run the projector in high lamp mode, which would reduce the life of the lamp..
Prof..
Home Theatre...the never ending story!
Old 04-20-09, 11:34 AM   #3
Alias: Cameron
User: #33698
Since: Feb 2009
  06'Goat is offline
thanks I might just stick with the 120"
Old 04-24-09, 06:54 PM   #4
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
I have a 106" screen and only get 7 FtL from my projector, so don't go too big or you'll have brightness issues
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 04-24-09, 07:44 PM   #5
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is offline
Ahmed...If you have the Epson EMP-TW2000..and you have a 106" diagonal screen with a gain of 1.0..
then you might be under estimating your fL..
According to the Pro-Calculator, you should be getting 18fL..from that distance..
An fL. of 7 would be very dull indeed..
Prof..
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
hc1500?, mitsubishi, screen, size
