| Home Theater Projectors whats under $3000 thats stupid good for the cash?Discuss whats under $3000 thats stupid good for the cash? in the Home Theater | Audio and Video forum; whats under $3000 thats stupid good for the cash? Just curious if you had $3000 and a controlled room to view in with centered ceiling mount what would you ... |
Views: 549 - Replies: 4
| whats under $3000 thats stupid good for the cash? Just curious if you had $3000 and a controlled room to view in with centered ceiling mount what would you look into? My fathers new home has a dealer right down the road and he offered a Planar DLP 7130 model that is 720P DVI for $3000 which IMO is insane and bodering on insulting so looks like I have to buy for myself. Any input would be great, thanks! | ||||
| | #2 | ||||
| Re: whats under $3000 thats stupid good for the cash? I installed a Panny 1080p projector not too long ago (AE3000U). It cost the client $2500, I believe with a $500 screen (fixed frame Elite), so about $3000 total. Projector was bright, quiet, and really easy to setup and configure. It also had a really good range of front/back adjustment for the screen size. The only thing I didn't like is the manual lens cap, but it was electric focus, so chances of disturbing it are minimal. My Sanyo Z4's auto-shutter has me spoiled ![]() | ||||
| | #5 | ||||
| Re: whats under $3000 thats stupid good for the cash? Also, if you want a CIH set-up, the ae3000u has lense memory and it makes it super easy to do a CIH set-up without an anamorphic lense. Although, you will loose resolution. | ||||
