Panasonic PT-AE1000 LCD Projector - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss Panasonic PT-AE1000 LCD Projector in the Home Theater | Audio and Video forum; Panasonic PT-AE1000 LCD Projector LCD™ Display Technology 1100 ANSI Lumens 1920 x 1080 Native Resolution 16:9 Native Aspect Ratio 11000:1 Contrast Ratio 15.9 lbs ...
Discount Merchant
Old 09-25-06, 04:27 PM   #1 (Link)
Loc: Lower Alabama
  • LCD™ Display Technology
  • 1100 ANSI Lumens
  • 1920 x 1080 Native Resolution
  • 16:9 Native Aspect Ratio
  • 11000:1 Contrast Ratio
  • 15.9 lbs
  • HDTV Ready
Panasonic PT-AE1000 LCD Projector Information
Manufacturer Panasonic
Manufacturer Part # PT-AE1000
Production Status Announced
Release Date NOV 2006
Panasonic PT-AE1000 LCD Projector Specifications
Aspect Ratio 16:9 (Native), 4:3
Brightness (ANSI Lumens) 1100 ANSI Lumens
Contrast Ratio 11000:1
Display Type 0.74" D6 LCD with C2Fine
Resolution (Native / Max) HD (1920 x 1080)
Video Compatibility PAL, PAL-M, PAL-N, PAL 60, SECAM, NTSC, NTSC 4.43, 525i (480i), 525p (480p), 625i, (576i), 625p (576p), 750 (720)/50p, 750 (720)/60p, 1,125 (1,080)/24p, 1,125 (1,080)/50i, 1,125 (1,080)/50p, 1,125 (1,080)/60i, 1,125 (1,080)/60p
Projection Lens F = 1.9 ~ 3.2 f = 22.4 ~ 44.8 mm
Number of Colors 1.07 Billion Colors
Size Dimensions (WxHxD) 18.1in. x 5.2in. x 11.6in. (45.97cm x 13.21cm x 29.46cm)
Weight 15.9 lbs. (7.21 kg)
Inputs S-Video x 1, Composite RCA x 1, D-sub HD 15-pin x 1, RCA pin (Y, PB/CB, PR/CR) x 2, HDMI x 2
Control RS-232 x 1
Power Supply 100 ~ 240 V / 50 ~ 60 Hz
Power Consumption 240W (Standard) 0.08W (Standby with Fan Stopped) Projection Lens Lamp Type 165W UHM
Lens Shift Horizontal: +/-40% Vertical: +/-100%
Projection Mode Front, Rear, Table, Ceiling
Projection Screen Size (Diagonal) 40in. ~ 200in. (101.6cm ~ 508cm)
Throw Distance 3.9ft. ~ 40.7ft. (1.19m ~ 12.41m)
Throw Ratio 100" @ 3 ~ 6m
Optical Zoom 2x
Vertical Keystone Correction +/- 30 Degrees
Brightness Uniformity 85%
H-Sync Range 30 ~ 70 kHz
V-Sync Range 50 ~ 87 Hz
Menu Languages English, French, German, Spanish, Italian, Chinese, Korean, Russian, Swedish, Danish, Norwegian, Polish, Czech, Hungarian, Portuguese, Thai
Features
14-bit gamma processing original LSI
Full HD-optimized Dynamic Iris with new algorithm
Waveform monitor function
Full HD-optimized Smooth Screen
Cinema Color Management
Progressive Cinema Scan (3/2 pulldown)
Scene-adaptive MPEG noise reduction
Lens-centered symmetrical design
Learning remote control
Built-in test pattern
In The Box
Power cord
Wireless remote control unit
Batteries for remote control (UM-3 x 2)
Old 09-25-06, 10:12 PM   #2 (Link)
Alias: Steve
Loc: Gold Coast Australia
Steve Williamson's Avatar
User: #496
Steve Williamson is offline
Re: Panasonic PT-AE1000 LCD Projector
Is this the next giveaway?
Old 09-25-06, 10:19 PM   #3 (Link)
Loc: Lower Alabama
Wouldn't that be exciting... I'd have to enter the giveaway myself...
Old 09-26-06, 12:09 PM   #4 (Link)
Alias: jagman
Loc: Sacramento, CA
User: #1455
jagman is offline
I vote for adding it to the giveaway !
Old 10-13-06, 11:13 AM   #5 (Link)
Alias: grumpydude
subloverman's Avatar
User: #2729
Since: Sep 2006
subloverman is offline
Hey sonnie
I have the old yet usefull ae-700, maybe time to sell it and upgrade!
If youre gonna do a giveaway on that.. I could do with saving some wedge for a change instead of blowing it all every 5 minutes summat new comes out! ha ha.
regards
SUB..
Got BASS?????
Old 10-13-06, 01:43 PM   #6 (Link)
Loc: Lower Alabama
lol... it would be hard to do a giveaway on that unit. Generally we trade out advertising for our giveaways and we don't have anyone advertising with us that sells those units right now. Maybe as we grow and get bigger we'll be able to do something this big.
Old 10-30-06, 12:00 AM   #7 (Link)
Alias: Steve
User: #496
This site has it listed for sale, hopefully it should start filtering through fro Christmas
http://www.buchmann.ch/products/Panasonic_PT-AE1000.htm
Runs out at just over AU$7000, not bad for a full HD projector, hope it gets cheaper though.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
Panasonic Reaffirms Commitment to Plasma HDTV and Launches New LCD Projectors at CEDIA Roger Home Theater, Audio and Video News 0 09-15-06 03:30 AM
Check out the first two Panasonic 103-inch plasmas this weekend HDBeat Home Theater, Audio and Video News 0 09-07-06 02:31 PM
Panasonic PT-AE900U HD Home Cinema Projector Deal Sonnie Home Theater Projectors 2 08-05-06 10:50 AM
Panasonic 103in Maneater Devours Girl: Are You Next? Wayde Home Theater, Audio and Video News 2 07-23-06 01:41 PM
Panasonic 50" problems kevsamp Video Displays and Processors 3 06-10-06 07:08 PM
Mach 5 Audio
