Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
planning stage
Discuss planning stage in the Home Theater | Audio and Video forum; planning stage hello if things continue to go ok for me = keep job. it looks like i will be going projector. ...
Views: 554 - Replies: 22
Old 06-21-09, 10:16 PM   #1
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
  Fabricator is offline
planning stage
hello
if things continue to go ok for me = keep job. it looks like i will be going projector. i have a 5 month old Mitsu 65" dlp & BD35 now. i just love the picture, but its almost to small, and that is when i use ZOOM. with a regular letterbox, it is to small.
i have a bathroom to totally remodel, so i can/want to wait for a sale. but what good is a sale, if you don't know what to buy. so, i am starting my research on what to get. so when that "sale" comes, i can pouch on it. and its going to take well over a month to do the bathroom, so this will be an ongoing thread.
screen size
my 65" is 32" tall. a 32" tall, but letterbox wide, screen would be fine. how wide would that be ? perhaps i should go bigger
it would be mounted about 2' from the wall = . maybe, but that is where my dlp is, and with the other gear, i like the screen there. perhaps i will wall mount later, idk.
i am going to build the screen, once i deside what to get.
projector
i want the picture to be as good as my dlp. is that possible ?
the projector would be right above my head, or there about. and i would prefer to not hear it.
i would like, if they can do it, for the screen to be letterbox. but have the projector be able to switch to 16:9 and downsize to fit the screen = black bars on the side. and display anamorphic(sp?) with black bars would be ok.
it would be nice to have a mode that could kick up the brightness(or whatever), if i should (RARELY) want to watch it during the day, compromised quality would be ok.
room
12x19x8, i'l show ya. it is not "dedicated" . but we, wife & i, don't real do much other than watch movies in there. i have no WAF, i do what i want. but, i do consider my wifes concerns/wants. she thinks i am and the screen will be to big. but she hasn't ever seen one, so doesn't have a clue.
i bet she will like it. anyway.... the room can be mostly blacked out during the day. though we pretty much always watch at night. during the winter, it is DARK, 5pm dusk, 7pm movie. you get the idea.
seating
about 10' distance.
budget
how about $3000ish total ?
i think thats most of it. will get me started anyway. so, whatcha think ? other things i have not considered ?
thanx a ton
Old 06-21-09, 10:25 PM   #2
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
oh. i think i am going to paint the room darker. not black, but a darker blown.
Old 06-21-09, 11:59 PM   #3
Owner
Loc: L.A. (Lower Bama)
Re: planning stage
You are describing the Panasonic PT-AE3000U, same pj we currently own. We have it set up on a 125" 2.35:1 AR and swap between 16x9 zoomed for 2.35 to s16x9 for 1.78 or 1.85 AR with the press of a button. It has lens shift and lens memory. Works great!
The pj is right above our seating and we never notice the fan running... it runs in econo mode.
$2499 at www.projectorpeople.com They gave me an extra year on the warranty and a free bulb warranty.
Out of the box it is one fine projector.
BTW... the walls look good... paint the ceiling black.
Old 06-22-09, 02:13 PM   #4
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: planning stage
I agree. That's a versatile projector. I have never owned a DLP TV. But Projector picture might be 4 times as big and to perceive the same quality of your smaller picture, resolution should be 4 times higher as well (all other parameters assumed the same). As you see it is not easy to compare, but I can garantee projector PQ on 1080p material is stunning!
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 06-22-09, 02:29 PM   #5
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: planning stage
By looking at your photos my guess is that you would be able to go with about a 96" diagonal screen (moving your front corner bass traps would give you more space). With the Panasonic PT-AE3000U your getting a great unit and given the screen size your going with it will be more than ample brightness and resolution.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-22-09, 07:31 PM   #6
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
Re: planning stage
You've treated the front of the room, but nothing on the side or back walls..
I would suggest to improve the sound further that you put panels on the side walls at first and second reflection points..and bass traps in the rear corners..
You have a highly reflective area with those sliding glass doors and they really need to be treated as well..
Prof..
Home Theatre...the never ending story!
Old 06-22-09, 07:46 PM   #7
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
thanx guys
i was looking at the AE3000. so thats the one i will get. just waiting on a sale, so if ya see one = lmk.
i'm not in a hurry. that part was easy
now. the sceen. i have judged 7' wide to be about the largest i could go. i need to leave room for my mains, i don't want em right next to the wall. were can i find out what the screen height would be for the different ratios ?
also. i could measure till the cows come home. but until i could SEE the actual image in my room, i could not make a final decision . so, what would be a CHEAP way to make a temporary screen ? so that i could actualy see, before building one. perhaps just using the wall would be ok, then downsizing for the 2' closer DIY screen.
does that make sense ?
and, compared to my 65dlp. what would the image loose ?
Old 06-22-09, 10:17 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: planning stage
The best thing you could do is wait till you get the projector and mount it where you want it. Then simply turn it on and try some different sizes and see what you like. Have a look here at this calculator it will help you with choosing the right size for the Panasonic.
Home theater:
Two Channel system:
My Webpage
Old 06-22-09, 10:43 PM   #9
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
will do, that sounds good.
Old 06-22-09, 10:58 PM   #10
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
how is that machine mounted ? i don't see any mounting points on top (i think).
Old 06-22-09, 11:32 PM   #11
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: planning stage
Fabricator wrote: View Post
It hangs upside down if you mount it on the ceiling and in the menu you flip the image and it will show the proper way around, very common with most projectors.
Home theater:
Two Channel system:
My Webpage
Old 06-22-09, 11:46 PM   #12
Owner
Re: planning stage
Whoever you buy it from will recommend a mount that they sell.
www.projectorpeople.com is offering a free mount right now.
* Receive a 2-year limited warranty or 2,000 hours limited warranty (whichever comes first, excluding lamp) Click here for rebate claim form. Offer good 4/1/2009 through 6/30/2009.
* FREE with purchase - 25 foot HDMI 1.3 cable, and universal projector ceiling mount! Shipping charges apply to promotional items. Offer good now through 6/30/2009, or while supplies last.
I think I paid about $150-160 for my Chief mount.
You usually won't find these discounted very much. The PT-AE2000U, last years model, is still selling for $2000.
Old 06-23-09, 08:51 PM   #13
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
thanx, guys.
the mount, i will make that = Fabricator .
i found a thread that said they were on sale for $2300 iirc, about 6 months ago.
as it is now, i have time to wait, and ask more questions. as the wife REALLY wants her bathroom/shower rebuilt. a complete gut. i think i am going to get started on that this weekend. so when its done, i will be open to get what "I" want
2 more Q's :
i am assuming its 120v power ?
and it "comes" with a remote ?
Old 06-23-09, 10:58 PM   #14
Owner
Re: planning stage
Yep and yep...
Old 06-23-09, 11:29 PM   #15
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
ok, this remote. when pointing it at the screen. will it work the projector ? remember, the projector will be mounted pretty much right above my head.
Old 06-23-09, 11:37 PM   #16
Owner
Re: planning stage
Mine is behind me. It will work most of the time ... bouncing off the screen, but for macros, it is not so good. A remote IR transmitter is needed for macros... or emitters.
Old 06-24-09, 10:22 AM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: planning stage
Sonnie is right, my remote turns it on and off just fine as well as the signal simply bounces off the screen.
Home theater:
Two Channel system:
My Webpage
Old 06-24-09, 10:27 AM   #18
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: planning stage
That helps believe it is a huge flat screen
ASME AI
Old 06-24-09, 08:08 PM   #19
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
good. but now that i think about it. once it is on and adjusted for the movie, what else is it good for
i was looking at that screen size site. seems a 7' wide anamorphic would be about 4" taller than what i have. so that is where i will start testing, when the time comes.
Old 06-28-09, 09:57 AM   #20
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
guys. i was reading on another forum. a guy* was saying that a 110ish" at 10-12' a 720 is the same PQ as a 1080p. "if" this is true, why would guys be spending $$$$ more for a 1080p ?
* = this "guy". i don't know how knowledgable he is. but he seemed to be.
Old 06-28-09, 01:31 PM   #21
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Re: planning stage
I believe the 'guy' is mistaken. I cannot recall the exact sweet spot but if I remember correctly it is in the 60" screen range. It all has to do with pixel size and your eyes. At such and such distance the human eye is incapable of perceiving the difference between the 720p pixel size and the 1080p pixel size.
Check out Carlton Bale's screen calculator and this link on 1080p and the acuity of human vision.
For a 110" screen, the max seating distance is around 14 feet for a 1080p display. For a 720p display it's ~22 feet.
Gain Readings
Spectro Readings - not up to date but will be soon
Old 06-28-09, 06:52 PM   #22
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
maybe that guys name is stevie wonder, lol. yeah, i figured it was something like that. that guys statements didn't make sense. and they were talking $500 projectors.
on a side note.
i tore out the shower stall today, and will start rebuilding. i am now that much closer to getting my projector.
Old 07-02-09, 10:31 PM   #23
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
Re: planning stage
hi, guys. another question.
i am trying to figure a way to get power to the projector. since i will/can have full coverage wall & ceiling panels, the wiring will hid behind it.
1.i could just run an extension cord up and over.
2.run new wiring in the wall(behind my gear), up to a new outlet close to the ceiling. then run an extension cord over the panels.
3. run BX through the wall and over the panels, to a new outlet.
4. run conduit in walls and then over the panels.
5. just hang an extension cord up to it when in use = kinda
i can't deside. #5 = last resort.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
planning, stage
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
