Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
First time bulb replacement... help please
Discuss First time bulb replacement... help please in the Home Theater | Audio and Video forum; First time bulb replacement... help please Hello all, Two years ago I bought an optoma HD 70 DLP projector and have enjoyed thousands of hours of ...
Views: 577 - Replies: 15
Old 07-01-09, 07:25 PM   #1
Alias: Tiny
MonsterMaddness's Avatar
Loc: Tuscaloosa, Alabama
User: #19096
Since: Apr 2008
  MonsterMaddness is offline
Hello all,
Two years ago I bought an optoma HD 70 DLP projector and have enjoyed thousands of hours of enjoyment, 2000 hours in fact. Now that it's time to replace the lamp I have some questions. Should I buy a new lamp or just a new bulb. A bulb is cheaper and I consider myself a pretty handy guy but I've never replaced one before and can't seem to find instructions on the net. Also, whether it's a lamp or a bulb, where should I buy a replacement? There's a lot of diffrent dealers out there and I've heard some of them are not above scamming a novice such as myself. Any advice would be greatly appreciated.
Old 07-02-09, 03:34 PM   #2
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Re: First time bulb replacement... help please
Hi,
Do you really need to replace the bulb? I wouldn't replace mine unless I get some serious dimming (brightness) issues. I know of people who have 5 Khrs on theirs...
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 07-02-09, 04:31 PM   #3
Alias: Tiny
User: #19096
Since: Apr 2008
Not really, I was going to stretch out the bulbs life as long as possible but would still like to order a replacement so when it does go, I can replace it and not miss a beat. Do you really know people with 5000 hours on their bulb?
Old 07-02-09, 04:39 PM   #4
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
I have read somewhere ... although mine burned out after only 1388 hrs and I had a replacement under warranty
ASME AI
Old 07-02-09, 04:58 PM   #5
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
There's a lot of different dealers out there and I've heard some of them are not above scamming a novice such as myself.
You can check the reputation of a store here:
http://www.resellerratings.com/
We're all in this together!
Members DIY Subwoofer Database
Old 07-02-09, 05:45 PM   #6
Alias: Tiny
User: #19096
Since: Apr 2008
So, new lamp or new bulb?
Old 07-02-09, 06:42 PM   #7
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is offline
I would go with a new bulb, in fact when my HD-72 needs replacement that is what I plan to do. Check this out...http://cgi.ebay.com/ws/eBayISAPI.dll...m=290310076294 I believe that bulb will fit yours also but call and make sure if you decide to go that way.
Old 07-03-09, 02:41 AM   #8
Alias: Tiny
User: #19096
Since: Apr 2008
So where can I find instructions on how to replace the bulb while keeping the orginal housing?
Old 07-03-09, 10:48 AM   #9
Alias: TC
User: #9814
Since: Jun 2007
  tcarcio is offline
You got me thinking about this and it looks like it might not be a good idea. I searched ''relamping a projector bulb'' and found alot of this kind of thing.....
There are some company's that will relamp for you but it sounds risky at best and may void your PJ warranty.
Old 07-04-09, 03:32 AM   #10
Alias: Tiny
User: #19096
Since: Apr 2008
Yeah, I actually watched that vid before. I figured it could be a scare tactic used to ward off cheap skates like me. However, the cheapest I've found the bulb is $200 and the entire lamp is $245 on amazon. If I could find a bulb for $100, I'd probably give it a shot but I don't think it's worth the risk for $45 bucks savings.
Old 07-04-09, 08:34 AM   #11
Alias: Fab
Loc: midwest
User: #36564
Since: Apr 2009
  Fabricator is offline
MonsterMaddness wrote: View Post
i know exactly what you mean. often its hard to know just who/what to believe. i am going through this right now, with my shower remodel. i am being told to rip out(no easy task, concrete floor and plumbing) something that isn't broken. and i can't figure out why.
anyway. let us know what you do. with pics.
Old 07-04-09, 08:36 AM   #12
Alias: Mike
User: #8033
Since: Apr 2007
The HD 70 uses a 200 watt UHP bulb. They can be bought for $60 plus shipping from "ywh" on the diyaudio.com forum. Ask him on the forum to make sure. He's in China and has been supplying lamps for a lot of people for the past 4 years. Post# 841, 842 and 843.
http://www.diyaudio.com/forums/showt...t=#post1048694
"18wheeler" has been stocking "ywh" bulbs in the U.S. You'll have to check if he has your specific bulb. Make sure you read the FAQ.
http://www.diypro.us/index.htm
Old 07-04-09, 09:52 AM   #13
Alias: TC
User: #9814
Since: Jun 2007
  tcarcio is offline
Mike, Have you replaced a lamp useing this method and if so how did it work out?
Old 07-04-09, 11:12 AM   #14
Alias: Mike
User: #8033
Since: Apr 2007
No I haven't. At one time I was going to build my own projector and was a member on that forum. I followed that thread for quite a while.
Old 07-12-09, 12:51 AM   #15
Alias: Tiny
User: #19096
Since: Apr 2008
I think I may go ahead and buy a lamp this round and then try to replace the bulb in the old lamps housing. Thanks for your help and let me know if any information becomes avalible out there!
Old 10-09-09, 10:49 AM   #16
Alias: Akan101
User: #41942
Since: Sep 2009
  akan101 is offline
I suggest you also get a lamp with the bulb sometimes people complain of incompatible with the other bulbs. Just check it this link out;
Optoma HD70
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
bulb, replacement..., time
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
