| Home Theater Projectors Not a happy camper........Discuss Not a happy camper........ in the Home Theater | Audio and Video forum; Not a happy camper........ Need to vent a little frustration as my Optoma HD72 pj lamp just went out with only 750hrs on it. ... |
Views: 637 - Replies: 12
| Not a happy camper........ Need to vent a little frustration as my Optoma HD72 pj lamp just went out with only 750hrs on it. This is the second bulb I have had problems with and the first bulb went with only 450hrs of use. I did some research and have found that this is a wide spread problem with this PJ and that the ballast does not like to keep bulbs running after they get a few hours on them. Thanks for letting me vent guy's because if I don't I will![]() ![]() Last edited by tcarcio; 07-20-09 at 06:03 AM.. | ||||
| | #2 | ||||
| Re: Not a happy camper........ That is too bad, I hope Optima will do something for you. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Not a happy camper........ Thanks T, From what I have heard I'm not holding my breath.... | ||||
| | #5 | ||||
| Re: Not a happy camper........ The HD-72. | ||||
| | #6 | ||||
| Re: Not a happy camper........ I recently bought an HD65.. I've only got about 200hrs. on the lamp and so far no problems.. I was reluctant to buy it because I had also heard that there were a lot of premature lamp failures with that model as well.. It seems to be a common problem with most, if not all Optoma models.. I've even heard that some owners have returned their projectors several times to Optoma for constant lamp failures.. I went ahead and bought it anyway, because it fitted all my requirements in the theatre..and it is a great little projector.. ![]() Optoma seem to be doing the right thing with no questions asked on replacements,(providing it's still under guarantee) but it's the inconvenience of being without your projector that I would find most annoying.. When I purchased my projector, I took out a 3 year warranty on lamp replacements, so at least I won't have to worry about that side of things.. I hope Optoma will do the right thing by you, even though you're just outside the warranty period.. Prof.. Home Theatre...the never ending story! | ||||
| | #7 | ||||
| Re: Not a happy camper........ Well I have been told that Optoma was replacing lamp drivers because of the problem but they didn't do that for me when I sent it to them. Now it has the same problem but it's out of warranty so I hope they fix it knowing that the problem existed while the unit was under warranty. I have not heard back from them yet and I am hopeing I will soon. I guess this is a major problem because I found this yesterday....http://googleads.g.doubleclick.net/a...Complaints.com | ||||
| | #8 | ||||
| Re: Not a happy camper........ I have heard of this issue but I'm not familiar with the name settings exactly. There is a trick that I have heard of that if you can set the lamp mode to "natural", "standard", or "normal", then turn up the brightness while keeping contrast relatively low then you can extend the life of the lamp. Also you should always run in "whisper", "cinema" or what it is called that lowers the lamp setting for the first 300 hours of bulb life. Then if you can correct the color you should at least get 1000 hours on the lamp. I would get in contact with them again and get the issue resolved because the lamp issue could possibly harm the projector being unstable and it will end up needing to be returned again. I would also see about trading in for the HD80. | ||||
| | #9 | ||||
| Re: Not a happy camper........ I had the PJ set up with bright mode off from the first time I heard of this problem. Now it doesn't matter what setting it is on because it won't stay on long enough to even mess around with it. It boots up and as soon as no signal comes up, which is about 15 seconds it shuts off. | ||||
| | #11 | ||||
| Re: Not a happy camper........ I did that multiple times. Anyway I just got an email from them and they are basically blowing me off. They even said the rma# that is written on the paper they sent to me when I ordered the first bulb was invalid. I sent them another email explaining how I feel but I don't expect they will admit any responsibility. I know one thing if they don't fix it I will never be buying or recommending Optoma to anyone.![]() | ||||
| | #13 | |||||
| Re: Not a happy camper........ Quote:
The other thing is the inconsistency of service between Countries of the same manufacturers products.. I believe in the UK, Optoma are doing everything possible to provide a good service in rectifying these problems.. I haven't heard yet of any service problems here in Aus..so I'm hoping they have the same attitude as the UK.. Prof.. Home Theatre...the never ending story! | |||||
| Bookmarks |
| Tags |
| camper........, happy |
| Thread Tools | |
