Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Reliable Hardware: A Reliable Source for Case, Cabinet and Acoustical Hardware! Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Elite Screens offers the finest in affordable projection screens. RAM Electronics: Audio, Video, Home Theater and Computer Cables. Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices ePVision.com: One-Stop place for High-end HDTV, Media hub in the box, Advanced ATSC/QAM/NTSC Tuner Receiver, Network HD Media Player and etc. Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! BOCS - Power Up Your Tivo! Musicians Friend: Your one stop shop for microphones, mic amps and Behringer products. SVSound GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels!
Home Theater Shack Stores Movie Stuff Vendors
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater | Audio | Video > Home Theater Projectors
Views: 465 - Replies: 7
Old 12-02-09, 08:44 PM   #1
Blktre's Avatar
Blktre
Since: Sep 2008
Ks
  Blktre is offline
Image concerns
Hi, Ive got some problems and plan on calling Epson in the morning.
I temporarily set up my Epson 8100 to test my HDMI cables i bought from Monoprice which are the 25ft High Speed Cat 2 CL2 22AWG in wall cables. I wanted to test my cables before pulling them. Anyways on to my problems...
Using my Samsung 1080p Upconvert DVD player in SD, at the very bottom i get a line that stretches the entire horizontal length. This line seems like changes color with whatever scene im watching. It obviously shows some other parts of the movie/images. The line is less than 1/4" and drives me crazy. It does this using both cables i have in both HDMI ports.
Also, watching HDTV thru my Motorola HDDVR i get a green line running vertically on the right side of the screen. Its at least 1/4" if not wider and runs the entire vertical side of the image. It does this on 4:3 and 16:9 broadcasts.....
I dont think this is caused from the cables, or could it be? Seems more like something wrong with the panels to me. This is a 3LCD PJ...any thoughts?
Thanks in advance.
Old 12-02-09, 08:56 PM   #2
tonyvdb's Avatar
Tony
Since: Sep 2007
Edmonton, Alberta, Canada
My Photos
  tonyvdb is offline
Re: Image concerns
With some projectors you may have to adjust the overscan as projectors usually come set up with maximum image and on alot of broadcast material this line can be the network signal that normally would not be seen. 1/4" does seem a bit excessive but thats my guess. The LCD panels being out of alignment would not cause this.
Have you tried a different HDMI cable.
Home theater:
Onkyo TXSR805, Samson Servo 300 amp
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba A30, Panasonic BD60, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV, Nintendo Wii
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, Samsung BDP1400, Sony turntable PS-T20
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 12-02-09, 09:11 PM   #3
Blktre's Avatar
Blktre
Since: Sep 2008
Ks
  Blktre is offline
Re: Image concerns
Nice Tony.....
The overscan worked. It was set to off. I guess i didnt understand what the definition of overscan was. I set it to auto and it fixed the problem using HDTV. The green line is gone. I now need to check using a DVD. I will report back.
Fwiw, i have two of the same HDMI cables.
Thanks again Tony, I owe ya!
Old 12-02-09, 09:40 PM   #4
Blktre's Avatar
Blktre
Since: Sep 2008
Ks
  Blktre is offline
Re: Image concerns
Ok. The one SD DVD i checked was a full screen movie. This DVD had the wired line at the bottom that ran horizontally. I put in a wide screen DVD and the problem was gone. So im wondering if the full screen DVD's will always cause this line at the bottom. My guess is yes. But i will keep playing. Thanks again.
Overscan fixed my full screen DVD's. Thanks for helping a newb. This is my first PJ. I'm shooting it on a piece of sheet rock for now....I need a screen!!
Old 12-03-09, 08:40 AM   #5
tonyvdb's Avatar
Tony
Since: Sep 2007
My Photos
  tonyvdb is offline
Re: Image concerns
Some DVD players dont do a good job of fitting the image of the video properly on the screen I have an older LG upconverting player and it has the image shifted slightly to the right and on my TV upstairs I dont see this but on the projector in our theater room it was very noticeable.
Home theater:
Two Channel system:
My Webpage
Old 12-20-09, 11:10 AM   #6
John
Since: Dec 2009
Clearwater, Ks
  jzb7 is offline
Re: Image concerns
Blktre,
How well does your 8100 do with standard DVD and with upconverting standard DVDs? I don't have HDTV yet, but plan to in the future. I have just regular Dish network and was curious of how good of a picture you get with it also? Any help from you or others that have the Epson 8100 would help. I have read where the 8500 has a good picture with non HDTV, but hate to spend that much on a projector. ........Thanks!!!
Old 12-20-09, 01:35 PM   #7
Blktre's Avatar
Blktre
Since: Sep 2008
Ks
  Blktre is offline
Re: Image concerns
jzb7 wrote: View Post
Blktre,
jzb7,
Ive had a little time to play. I have around 19hrs on my bulb. I'm shooting it onto a stock piece of 4x8 sheet rock. This is a very temporary solution until my screen arrives. So I haven't Calibrated because of the screen issue. But I'm impressed so far with the settings right out of the box. The image pretty much fills the entire space. Throw distance of 13"4'. Ive viewed it with ambient light during the day watching HDTV and SD DVD's. The color setting was set to Living Room. The brightness was real good and decent color saturation considering the ambient light. One of the reasons I purchased the 8100 was because of the lumen output and it doesn't fail in this dept.
Ive also watch HDTV and SD DVD's at night with ambient light very controlled. Color setting to Theater Black 1. Very impressive. One of the set backs of PJ's at this price point is deep blacks. This is my first PJ and I can say I'm extremely satisfied with the black levels. Color saturation, skin tones, etc right out of the box is very, very good. The 8100 up converts nicely. Way better than my Samsung 1080p Up convert DVD Player. So I leave the Sammy outputting native and let the 8100 do the Up converting. You will be happy with the SD DVD playback. Best Ive personally seen.
As far as HDTV goes, I have cable. And as you know not all HD channels actually broadcast in full 1080p. But, channels like Discovery HD, ESPN HD looks super impressive. Other HD channels broadcasting in 720 also look great, but not as good as the channels that broadcast in 1080. But im being picky. I also checked out some Digital Channels. Of course you get the 4:3 letterbox, but have the opportunity to change aspect ratios on those channels. You cannot change aspect with HD channels. The picture still looked good (acceptable) but of course nothing like HD or SD DVD. I should have a BD player for Christmas and things will be super impressive then.
I chose a 106" High Contrast Grey surface with a gain of .8 from Draper. I'm also in the running for the Elite Electric Screen and hope to get that (everyone does and good luck to those). But if I don't win it, then my Birthday in Jan. hoping to get some cash to go towards the Draper.
So imo, if the 8500 doesn't budge off its price point, the 8100 is your next best choice and to tell you the truth, it offers a of alot for the money. Remember, the 8100 replaced last years 6100 which was around $2400.00 I do believe. Anything else, just holler.....
Cheers,
Andy
Old 12-23-09, 03:45 PM   #8
John
Since: Dec 2009
Clearwater, Ks
  jzb7 is offline
Re: Image concerns
Hi Andy! Thanks very much for the info. I hope that you get your new screen soon. I hope that you and your family have a very merry Christmas!!!!!
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater | Audio | Video > Home Theater Projectors »
concerns, image
Bookmark and Share
Dish Network
Search Engine Friendly URLs by vBSEO 3.3.2
