A Question for the 'projector guys', sound deadening box - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 12-26-09, 12:06 PM Thread Starter
Matt
Hello, I just got a new "Pro Amp", a Lab Gruppen PLM 10000Q with Lake Processing Gonna make a post about that soon (I don't know of anyone else on here with Lake and I am getting pretty good with it so I could answer questions)... Anyways, the amplifier has variable speed (but always on) fans; I plan to either stick in in my closet, or build a box (with an air in and out 'side') to deaden the fan noise. I have heard of this being done on projectors, if anyone has any experience, tips, or advice please let me know! Thanks
-Matt
EDIT: yes, I know there are 'fan mods'... This amp has a 6 year warranty and has a MSRP of ~$9K so I am not going to go that route
Chester is offline
post #2 of 11 Old 12-26-09, 04:34 PM
mechman's Avatar
Steve Mechelke -mech
Re: A Question for the 'projector guys', sound deadening box
Diy - you need to make sure you keep air flowing through and around the projector. And that would mean the addition of a fan or two.
Commercial - here's a company that makes hush boxes.
Let us know which route you're gonna take.
mechman is offline
post #3 of 11 Old 12-26-09, 04:37 PM
mechman's Avatar
Matt - I just re-read your post. Are you looking for a hush box for your amp? If so I can move this to the amp forum instead of the pj forum. Let me know.
mechman is offline
post #4 of 11 Old 12-26-09, 05:09 PM Thread Starter
Matt
Thanks for the reply, Yes; I am looking for a "hushbox", I have heard of them being used for projectors before so thats why I posted in here It is up to you regarding moving it, wherever you think it will get better responses
the amp page is here so you can see what were dealing with:
http://www.hometheatershack.com/foru...rocessing.html
Chester is offline
post #5 of 11 Old 01-09-10, 02:12 PM
Instal
Chester wrote: View Post
This might be a long shot but you might want to look at your local business equipment dealers. They might have a old dot matrix printer hush box that you could get for cheap then modify to your liking.
Instal is offline
post #6 of 11 Old 01-09-10, 02:18 PM Thread Starter
Matt
hmm good call, I actually got some 8 AWG wire (4x 17' sections) and put the amp in my closet for now however the printer hush box sounds like a good thing to try
Chester is offline
post #7 of 11 Old 01-09-10, 02:30 PM
tonyvdb's Avatar
Tony
How hard are you going to run the amp? I highly doubt that it would run the fan at high if your only running it at half its output. does the fan always run or is it on demand?
You could pipe the exhaust of the amp out of the room using some 3" or 4" PVC the sound would be dramatically reduced going that route.
Home theater:
Living room system:
tonyvdb is offline
post #8 of 11 Old 01-09-10, 02:39 PM Thread Starter
Matt
The fan constantly runs, however it does 'ramp down' (after an initial turn on cycle with the fans at full for a few seconds) so it is pretty quiet when it is cooler in temperature, I have not pushed the amp too far yet (don't want to blow anything), the sub is a dual 1.5 ohm voice coil and typically there is more current than voltage going out on the sub channels so it is seeing less than 1 ohm at some frequencies... that being said, even driving it quite loud the most I have ever seen the channel power output (V*I) on the sub was at 40% peak output capability (the amp has a 4 hour log of its voltage, current, power, and temperatures, among other stats on a per channel basis)... the temperature has never gotten above 30% on any channel, so it is not being driven too hard
The closet is relatively large and does not heat up much when using the amp in there for many hours so for now the closet is working well.
Chester is offline
post #9 of 11 Old 01-12-10, 01:57 PM
MatrixDweller's Avatar
Zip
I guess that would be the benefit of having a well designed AV closet or rack enclosed in a wall: silence and good cooling.
MatrixDweller is offline
post #10 of 11 Old 01-12-10, 03:42 PM
lsiberian's Avatar
lsiberian
Rock wool is used to deaden industrial noise. It also absorbs heat well.
lsiberian is offline
'projector , deadening , guys' , question , sound
