Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Home Theater - Audio / Video > Home Theater Projectors
Donations Reviews Vendors
Views: 106410 - Replies: 19
Old 12-07-06, 03:46 AM   #1
drf
drf
Since: Oct 2006
Somewhere else.
  drf is offline
I started this thread.
how long can VGA cable be run?
One of my clients has asked me to install a projector and screen when I upgrade and tune their P.A setup. I can find out about projection distance, angle and keystone correction however i am a bit unsure of the maximum distance I can run a vga cable before we start to loose image quality. The projector will get its signal from a HP laptop. Currently we need to run the cables 25 metres.
Thanks,
dr f
Old 12-07-06, 07:32 AM   #2
Bob
Shueyville, Iowa
  bobgpsr is offline
Re: how long can VGA cable be run?
I've heard that about 10 metres is the longest you should try to run VGA without using booster amps.
Bob
Old 12-07-06, 09:58 AM   #3
Bronze Supporter
basementjack's Avatar
jack
Since: Sep 2006
Chicago Suburbs, IL USA
  basementjack is offline
I've run 50 feet with no problem at all, as in no even a hint of a signal problem. It really surprised me.
My advice would be to use a single run of cable with the only connections being at the laptop and at the projector.
Ensure the cable you use is constructed of 3 co-ax cables internally - straight unshielded wire will not cut it.
PIMFG.com sells a 100 foot Male-male cable with one RF choke $34, (75 foot is $27)http://www.pimfg.com/product_list.as...earchstring=68
These are the cables I've used with good luck.
Be sure to put the RF choke on the end near the laptop - as the choke's purpose is to reduce RF noise, which is more likely to enter at the laptop than it is at the projector.
Hope this helps.
Old 12-07-06, 12:04 PM   #4
My Photo Gallery
  brucek is offline
Huh, I would have thought that it would be best to install a choke closest to the equipment you want protected from the interference, since at that location any RF produced at the transmitting end combined with any interference picked up along the cable would be choked.
I would think that you could run ~100 feet with a high quality HD-15 cable.
Old 12-07-06, 02:33 PM   #5
elmac
Inactive
Posts: n/a
VGA-Analogue is not going to have as long a range as DVI. Using high quality cables I would say that 10 meters would be the maximum for 1024x768@60Hz. There are VGA-Analogue repeater solutions as well that can also permit 10's and 100's of meters of signal--at lower resolution let say 800x600@60Hz
Try good cable, and if that doesn't work you will have to install repeater.
Old 12-07-06, 07:30 PM   #6
Rodny Alvarez's Avatar
Rodny
Millbrook AL
My Photo Gallery
  Rodny Alvarez is offline
I have a 24 ft cable from my Dell comp to my pj and have no problems! http://lindy.com/
Old 12-08-06, 02:57 AM   #7
drf
drf
Since: Oct 2006
Somewhere else.
  drf is offline
Thanks guys, I found a local supplier of cable and will try the longest run they sell (15metres I think) then add 5 metres at atime until the signal degrades too much to use. It looks like lindy has an australian arm, and supply boosters so I know I can get one if necessary. At least I can go to my client with some knowledge on this, were as before I would have to say I didn't know.
Old 12-09-06, 04:13 AM   #8
Dan
Australia
  Danny is offline
I personally wouldn't run the cable more than 10metres without the booster, even if it works with the HP notebook you must consider what would happen if they hooked up another notebook that had a weaker signal. Just a thought.
Old 12-09-06, 04:32 AM   #9
drf
drf
Since: Oct 2006
Somewhere else.
  drf is offline
Thats a good point, I don't know what the chances of that are, but i will certainly keep that in mind when sorting out the final plan of installation.
Old 06-02-07, 08:19 AM   #10
phaseshift's Avatar
Gui Lao
Since: May 2007
Shenzhen, China
  phaseshift is offline
While I can not give a definite answer, I can say that I have run into _big_ problems with this when we tried (ignorantly) to lengthen a VGA cable by adding on another F-M cable. Tried an amplifier and it was not much of an improvement, but wouldn't you know, a new cable the right length fixed it in an instant.
The run is about 60 feet and we added about 5 feet to that in order to move the PJ. The actual PJ is a Benq something or other. It is a mid level 720 resolution and even though it has HDMI, it is a conference room PJ and mostly sees use with spreadsheets, eDrawings and junk like that.
We certainly learned our lesson on the VGA cable deal. Painful, but a well learned lesson for sure. Based on my experience, I would certainly not recomend extending the cable if it is already there and you just need a little more; it sure messed us up.
 Reply     Post New Thread     Back to Top of Page
« Home Theater Shack > Home Theater - Audio / Video > Home Theater Projectors »
cable, long, run, vga
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
