Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
How Long Does Your Projector Lamp Last?
Discuss How Long Does Your Projector Lamp Last? in the Home Theater | Audio and Video forum; How Long Does Your Projector Lamp Last? Please let me know how often you have changed lamps in your projectors!!! Well, I just changed the second lamp ...
Views: 8019 - Replies: 32
Old 02-14-07, 11:36 AM   #1
Banned!
Alias: majorloser
User: #757
  majorloser is offline
Well, I just changed the second lamp on my Optoma H78-DC3 after 630 hours and about 9 months (of course after the 6 month warranty). The first lamp was replaced after about 500 hours.
The first lamp was replaced because the lamp was so dim the projector couldn't adjust the brightness up high enough to display the colors properly. The bulb did not burn out and did not trigger a lamp fault indication on the projector.
The second lamp triggers the lamp fault and shuts the projector down. I can turn the projector off and then on again and the projector would start up....but not always. So I changed the bulb.
I run the projector in "normal" mode, not "bright" mode so I'm not running the bulb at high output.
Ok, I'm not being picky since I don't have a problem changing a lamp every year. Just the cost of doing business as far as I'm concerned. I just wish the lamp would last for one year. My previous Yamaha DPX-1 lamps would last between 700 and 1,000 hours with no problem, but those lamps were rated for 1,000 hours. No complaint there. (Granted, I ended up getting rid of the Yammie after 2 1/2 years after the DLP driver board blew and repairs would have cost almost as much as the Optoma I replaced it with.) But Optoma says the lamps should last for 2,000 to 3,000 hours.
Does anybody think I should send the projector into the factory for a "checkup"?
After the first lamp went very dim the factory said to send the projector in for service. But if all it needed was a lamp they would change the lamp and charge me bench time + the lamp + shipping. That didn't make sense to me then when changing the lamp is so easy (even a caveman can do it). I changed the lamp and everything was OK. So I figured that was that, problem solved. But now I have this problem with the second bulb after just over 600 hours.
I'm just not having good luck with projectors
Old 02-14-07, 11:44 AM   #2
Alias: Dougie
Loc: Pittsburgh, PA
User: #1263
Since: Jun 2006
  Dougie085 is offline
Re: How Long Does Your Projector Lamp Last?
Definitely, It sounds like your either getting bad bulbs or something is wrong with the projector. If I had to change 2 bulbs before the thing was a year old I would definitely get it checked out! Optoma's customer service is EXCELLENT! I did a warranty through them and they never even asked me for proof of purchase or anything...so I'd give them a call or email and ask them about it.
Old 02-14-07, 12:37 PM   #3
Bronze Supporter
Alias: jack
basementjack's Avatar
Loc: Chicago Suburbs, IL USA
User: #2649
Since: Sep 2006
  basementjack is offline
I would send it in also.
the cost of bulbs is too high to replace after 5-600 hours.
plus if they find something wrong with the PJ, they might just give you a free bulb.
You might also check to see that your mounting conditions aren't adding extra heat.
I have an epson PJ behind a glass window in my setup.
my old projector was rear venting so it wasnt a problem.
the epson is front venting so it's throwing heat right at the window.
All that heat is getting trapped, so I added a $10 box fan to the shelf, and blow air over the whole area, now it's nice and cool...
- Jack
Old 02-14-07, 05:18 PM   #4
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is offline
I think I would be jumping up and down on somebody if my lamp only lasted for those short hours..
That's terrible...Definitely sound like a bad unit...
I would be asking for two replacement lamps after all that trouble..
Old 02-14-07, 05:56 PM   #5
Alias: Bob
Bob in St. Louis's Avatar
Loc: St. Louis, Missouri, USA
User: #3243
Since: Oct 2006
  Bob in St. Louis is offline
Is the unit in an area where it's building up heat? That'll cook 'em QUICK!
If it's "out in the open", that's WAAAYY to often to be messing with high dollar bulbs.
Are you buying the bulbs from the manufacturer, or "O.E." bulbs, not some cheap "off brand" bulb?
Does this unit have an air filter that may be clogged? That'll buld up heat too.
My Sanyo PLV Z2 is about one year old and runs 2-3 hours almost every night, and runs on the weekends almost ALL DAY. I've never replaced a bulb, and it's not shown any signs that it's getting dimmer.
I've not found where on the menu to find the "HOURS USED" or "LAMP LIFE"..... but I feel at this point I've gotten my monies worth out this bulb.
Call tech support, or email them (IMHO)
Bob
Old 02-14-07, 08:40 PM   #6
Alias: Rodny
Rodny Alvarez's Avatar
Loc: Millbrook AL
User: #158
  Rodny Alvarez is offline
My Sanyo PLv-z3 its about two years old and we watch at least 4 movies a week and there is no sing of the bulb needing to be replace, I agree with everybody else, you need to send it back!!
Old 02-14-07, 10:12 PM   #7
Banned!
Alias: majorloser
User: #757
Yes, it's in the open in an area where the AC duct blows past it.
I only buy OEM bulbs directly from Optoma (or any equipment manufacturer).
I use my projector almost every day for 3 to 4 hours straight.
Yes, the filters are kept clean and the unit is kept clean of dust.
Yes, the unit is on an APC SmartUPS that has AVR (auto voltage regulation).
To be honest, I'm just tired of sending equipment back to factories and waiting. I've got many nightmare stories that I just don't want to get into.
But, I'll see if Optoma can do anything for me
Old 02-15-07, 06:35 AM   #8
Alias: Bob
User: #3243
Since: Oct 2006
When I had a problem with a Harman Kardon, they told me to check thier website for an authorized repair shop that is close to me. I had to drive about 35 miles, but it was much quicker than shipping it off somewhere.
Bob
Old 02-15-07, 02:33 PM   #9
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
My first lamp lasted about 480 hours. It developed a 'flickering' problem. Sent it back to Mitsubishi and they replaced the lamp for free. They also stated that the lamp should last at least 2000 hours with the average being 3000-3500 hours.
It could be a bad ballast.
mech
Old 02-15-07, 05:17 PM   #10
Alias: Dougie
Loc: Pittsburgh, PA
User: #1263
Since: Jun 2006
When I sent my projector off to optoma it was gone about 2 weeks. So not very long.
Old 02-16-07, 11:42 AM   #11
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
majorloser, I have an Optoma H31 with about 3200 hours on the original bulb. You definitely have a problem. You might want to check your line voltage for surges (get a voltage cleaner/regulator if necessary). Is your projector properly ventilated? Make sure to keep it free of dust. It does sound like a projector problem, but, the above issues could be contributing to the problem. If you have the "high altitude" setting on your proj. use it as it will speed up the fan and keep the bulb cooler. Let us know what happens. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-19-07, 01:29 PM   #12
niget2002
Inactive
Alias:
User: #
Posts: n/a
We had a Panasonic here at work eat bulbs like that. It ended up being a bad power board in the Projector itself. Panasonic replaced the bulb, the board, and sent us a second bulb for the first one that blew prematurely.
Old 03-06-07, 07:10 PM   #13
Alias: norpus
norpus's Avatar
Loc: Melbourne
User: #3037
Since: Oct 2006
  norpus is offline
niget2002 wrote: View Post
Wow that is good service from Panasonic. Wish they had service like that here in Oz. Only horror stories of 500hr lamps and of sorry service here with Pana, although thankfully I never had to use them on my ae700 - was at 1200hrs and dim when I sold on that pj - it would never have lasted the 3000-5000hrs marketing spiel due to fading brightness (only had 4fL on a 108" screen on high lamp at last calibration). Sold it with a new lamp from price japan so new owner was very happy.
Cheers
Norpus
Old 07-28-09, 03:27 PM   #14
New Member
Alias: Phillip
Loc: De Leon Springs, Florida
User: #40005
Since: Jul 2009
  pwoon is offline
Well, I have an Optoma EP719, and it's been almost 4 years, and the lamp still works. I've just started using it regularly to watch TV on the DirecTV HDDVR last year during the Olympics. Before that it was just to watch movies. I don't know how much longer it will last.
Old 07-28-09, 03:47 PM   #15
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
  drdoan is offline
Just FYI. I retired my Optoma H31 proj. for a BenQ W5000. The Optoma has 7,000 on the original bulb and is still going strong! If anyone wants to buy it, I am including a new bulb, but, It will be interesting to see exactly how long the original bulb will go! Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Old 08-12-09, 10:30 AM   #16
Alias: Greg
Loc: Denver, CO
User: #55
  GregBe is offline
It is great to hear some of these stories. Most of the post you read are about problems, when I got my pj, I was expecting to change out the bulb every year or sooner. My bulb is rated at 4000 hours, so if I get even close to half of that, I will be pumped.
Old 08-12-09, 11:10 AM   #17
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is offline
Well I hate to bust up the Optoma love affair, But my HD72 is on it's 3rd bulb and none have gone past 900hrs. The first time I sent it back they said it was the bulb and so I replaced it even though I mentioned that people were having problems with what was thought to be a bad ballast desiegn. They denied it and when the new bulb went out at 870hrs the PJ was out of warranty and Optoma said too bad soo sad. Then said for 350 bucks they could replace the ballast I have a Benq that has 2300hrs on it and is still working fine. Personally I will never buy another Optoma but you may have better luck. I hope you do.
Old 11-03-09, 04:23 AM   #18
Alias: Machismo
User: #44048
Since: Oct 2009
  Machismo is offline
Generally there seems to be quite big differences between individual lamps.
Old 11-12-09, 10:40 AM   #19
Alias: Akan101
User: #41942
Since: Sep 2009
  akan101 is offline
Well i think that to prolong your projector lamp life you should take care of few things. Please see this article. http://www.squidoo.com/tipsforlamp
Old 11-12-09, 11:17 AM   #20
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
The most important factor is the frequency of starting the lamp. One should avoid shutting down and restarting over brief periods. The start cycle applies very high voltage pulses to start the arc and wears the lamp faster than running it, to a point. The break-even point is probably somewhere between 1-4 hours of use, according to reps from Osram and Philips.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 11-14-09, 10:19 AM   #21
Alias: Akan101
User: #41942
Since: Sep 2009
  akan101 is offline
Hey guys please do read this article Tips for prolong of lamp
Old 11-14-09, 11:00 AM   #22
lcaillo's Avatar
User: #328
  lcaillo is offline
You linked to it once already. More is not necessary. I read it and made my comment because it left out the single most important consideration in lamp life, start cycles.
I researched the issue of cool down many times with engineers from the manufacturers of the projectors and the lamps. The ones who know more than just repeating the owner's manual understand that thermal lag and uneven cooling are not a significant issue in most projectors. It certainly is good advice to let it cool properly, but not the only, nor the most important issue.
Old 11-15-09, 12:35 AM   #23
Alias: Mike
Loc: Sacramento, CA
User: #20692
Since: May 2008
  tiggers97 is offline
I've got a Mitsubishi 4900 in econo mode. Supposed to last 5000. So far I'm on about 500
Old 11-16-09, 10:50 AM   #24
Shack Moderator
Alias: Dr Doan
User: #2314
Since: Aug 2006
  drdoan is offline
My optoma H31 (which is for sale) has over 7,000 on the original bulb. It was still strong when I replaced the projector. Have fun. Dennis
L Dennis Doan, DC
IT'S THE NERVE!
www.drdoan.com
Direct TV DVR HD
Old 11-16-09, 11:48 AM   #25
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Bulb life can be dramatically affected by the climate you live in as well. If you live in a location that is very hot and your A/C does not work well or you dont have any that will kill a bulb a lot faster as well. Projector placement is also crucial in that it must be able to breath properly good air flow around it is a must. Remember that heat rises and if your projector is right against the ceiling that can also create problems.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
