Help picking screen for Infocus 4805 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss Help picking screen for Infocus 4805 in the Home Theater | Audio and Video forum; Help picking screen for Infocus 4805 A friend of mine decided he didn't have time to set up his HT so he GAVE me his Infocus ...
Discount Merchant
Old 04-06-07, 01:12 PM   #1 (Link)
New Member
Alias: Rikk
Loc: Springfield, MO
User: #487
Medicine Man is offline
A friend of mine decided he didn't have time to set up his HT so he GAVE me his Infocus 4805. It had set in the box for a little over a year without more than 30 minutes of play time. I wanted to by something more up to date but then I thought I would wait a little while for the 1080P projectors to come down in price. Besides, the reviews for this projector are great and why spend money when you don't have to? Anyway, what screen (gain, size etc.) would you recommend for a 16x12' dedicated HT with this projector?
Old 04-07-07, 08:36 AM   #2 (Link)
Alias: MACCA
Loc: Australia
MACCA350's Avatar
User: #149
MACCA350 is offline
Re: Help picking screen for Infocus 4805
I have the Infocus X1(which is is the same as the 4800) I built a 100" screen using this Dazian material, seating is about 12 foot from the screen, works great.
cheers
MAIN=100" Projection:Epson EMP-TW1000, HD DVD Player:Toshiba HD-XE1, Receiver:Denon 3805, Fronts:3xWharfedale Modus one-six, Surrounds:4xWharfedale DFS-23, Subwoofer:Velodyne DD15, etc....
BEDROOM=Denon 1603, Denon 2200, Teac 68cm CRT, 2xWharfedale Modus 2 Mains ,Wharfedale Modus Center, 2xWharfedale Diamond 9.DFS Surrounds, Velodyne CT100e, etc....
Old 04-07-07, 10:58 AM   #3 (Link)
New Member
Alias: Rikk
User: #487
Thanks for the reply I noticed the gain on the material is 0.95. Does the image that you have seem bright enough? The lumen output on the 4805 is not that great but I know thats what you give up when you have higher contrast ratios. Think that would be ok or preferable? How did you put your screen together? Thanks again!
Old 04-07-07, 07:33 PM   #4 (Link)
Alias: MACCA
Loc: Australia
MACCA350's Avatar
User: #149
MACCA350 is offline
I tried numerous materials from fabrics to plastics some with higher gain, I found that those with higher gain had problems with uniform reflectivity. The way I tested this is using Avia's full color field test's, while looking at the screen with these single colors the higher gain screens would have brighter and duller parts on the screen, and as you walk around the room the color shifts and is not uniform across the screen. With the Dazien material you get a perfectly uniform reflection that does not change as you move around holding the integrity of the projected image. For me this outweighed the slightly lower brightness, but as our room is light controlled this was not a big issue for me. Also the Dazian material is a thin stretchy PVC(so it's easy to clean) with very fine ridges that run diagonally that can only be seen from a few inches away, I think this is what also gives it an excellent uniform reflectivity
I must say this thread is looking interesting and I may try that material and see how it stands up to my tests.
I built my first screen using a method similar to this with an extra frame in front(using angled edge board) covered in velvet for the picture frame, but it would be easier to use this material. You could also try this, but I think the strain of the material would pull the sides in and warp the frame.
What I now use is an aluminum frame covered with velvet with springs to keep constant tension on the screen(similar to a trampoline) This is more costly because I had to have the frame custom bent, but the springs were actually cheaper to have custom made than off the shelf. Here is a pic of the back
And here is the profile of the frame
cheers
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
What Screen to use?????? James Broccoli Projector Screens | DIY Screens 7 04-11-07 01:54 PM
FS: Infocus 4805 with Oppo 971-low hours! chas Classifieds - Video Displays and Projectors 0 03-10-07 09:50 AM
Infocus 16 X 9 screen today only $30 chasw98 Projector Screens | DIY Screens 0 09-22-06 04:28 AM
InFocus IN76 Video Projector Review Wayde Home Theater, Audio and Video News 0 08-14-06 02:50 PM
InFocus ScreenPlay 7210 HD DLP Projector JCD Home Theater Projectors 0 08-14-06 11:55 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
