Epson 8350 vs Mitsubishi HC4000 - Page 2 - Home Theater Forum and Systems -
post #11 of 19 Old 05-20-11, 07:14 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Re: Epson 8350 vs Mitsubishi HC4000
The Epson 8350 doesn't show any offset in the calculator because it has lens shift..
This means you can mount the projector to the ceiling or put it on a table..
The HC4000 (which doesn't have lens shift) is more critical for projector positioning..
Home Theatre...the never ending story!
Prof. is offline
post #12 of 19 Old 05-20-11, 07:29 PM Thread Starter
Gents, thanks for all your thoughtful replies. I'm going to go with the Epson 8350. I'll report back in a couple months once everything's up and running!
ChristianCrowley is offline
post #13 of 19 Old 05-21-11, 10:04 PM
War Eagle!!!
Herbchemist wrote: View Post
Prof - thanks for the link...that calculator works great for the Mits HC4000. However, when I tried to compare it to the other projector (e.g. Epson 8350), there is no offset listed. I also noticed that you couldn't select a ceiling mount for this particular unit. Is this because the Cannon doesn't have this feature?
BTW - I found your comments just in time as I was prepared to purchase the 8350, but now am leaning toward the HC4000...I love sports as well.
Epson has vertical and horizontal lens shift, so you can move the lens up/dowen and side ways...It's much more flexiable in that regard...ther are pros/cons to each technology..IMHO the mits hc4000 is much better than the 8350 if you can live with the mounting restrictions and are not RBE sensitive.
bishoptf is offline
post #14 of 19 Old 05-22-11, 02:40 PM
rubbersoul's Avatar
Jumping into this mix a bit late but could not resist when I seen the comparison between Mitsubishi and Epson. I recently purchased the Mitsubishi HC6800 and I am very pleased with it's performance..just out of the box.
I intend to try my first hand at calibration in the next week or two using Disney's WOW blu-ray calibration dics. I had a bit of trouble using the Spears and Munsil calibration disc.
For me the S&M was confusing however I kow that their are a lot of people on the forum that rave about this disc.
Wanting to calibrate the Mitsubishi myself I choose from what I was told a disc meant for dummies.
We will see.
Although the Mitshubishi HC6800 is LCD I have not seen any evidence of motion blur. I watch some sports and I admit it is not my main venue however I have recently watched The Flyers series (sadly) and I was very pleased with the performance of the 6800.
That being said. It is why there is chocolate and vanilla ice cream. Choices.
I just wanted to express my experience with MItsubishi and and LCD projector.
I have a dedicated room with NO ambient light but not the best ceiling height. Upstairs my living room into the dining room entrance there is a step. Transcribe that step into my basement which I transformed into a Home Theater room and you can see that I have two ceiling levels. One ceiling level at exactly 6'1" (where the HC6800 is located) and another at 7'5" (where my Da-Litte screen is located).
So using projector central model calulator (which was very helpful) I had the HC6800 set back from the screen at a distance of 13'5".
My screen is 105" diagonal. I was unable at that distance to project the entire picure onto my screen. The width of the projected picture was ABOUT 1" smaller than the screen.
The short story is I had to move the projector back. I choose to move it another three inches giving it from the screen to the lense a total distance of 13' 8".
With those measurements all went well. Beautiful picture!!
The color factor with the Mitsubishi HC6800 brings out a vibrant image. Hopefully I am as successful with the calibration. Sometimes I stare at the picture I have now and wonder "how much better can this picture get?"
No matter what chioce you make Christian it will be the right one....and you will love the experience.
FYI...would apppreciate any thoughts about this situation of late. I also purchased a Sony CSX960 mega blu-ray player. Beautiful picture I am receiving....just watched the new Tron movie yesterday as well as Terminator Salvation. Had to do a firmware update on the unit as soon as I had it connected. Everything worked fine until I try to go to the HOME menu. When I try to go to the HOME menu it only stays on for a few seconds and then it goes to a blue screen and no signal mode from my projector. The dealer has ordered another unit to swap out my 960 since tech support feels it is a glich in a chip in the Sony. I am waiting for the new unit to come in probably by weeks end.
Has anyone dealt with this problem in there 960 or any blu-ray, dvd player?
Since this is the first time that I have had a problem with a electronic piece of equipment just out of the box I expressed my concern to the home and audio dealer about the next step in the event the second unit malfunctions.
I realized that it it rare but it does happen in a certain percentage of products.
I more than tripled checked my connections but tech support at the Home and Audio store I purchased this unit from said that it does NOT sound like a setup problem that does not involved anything that I did or did not do.
Just wanted to hear what the thoughts were of Home Theater Shack forum members opinion.
One last not. The H&A store I purchased this unit from that they would stand by me until this issue is they should but I was glad to hear it come from their lips.
Thanks everyone.
Thanks and goood luck Christain...have lots of fun!
Mitsubishi HC6800/Da Lite Screen
Outlaw 990/7700,
Emotiva XPA1 x2
B&W 804S mains/HTM3S CTR,3-DS7's surrounds/rear center
JL Audio Fathom 110,113
Sony 777 multi disc DVD player,Oppo BDP93
Comcast/Cisco Hub,Audio8,Monster,Tributaries power cord,BJC,Legend Audio
Furman Elite,Bryston BDA1 DAC,Chordette[/url]
rubbersoul is offline
post #15 of 19 Old 05-23-11, 10:53 AM Thread Starter
Thanks for your stories Frank!
post #16 of 19 Old 08-06-11, 11:07 PM
hey am facing same problem between two choices ,but after i saw this
i kinda change my mind .
waleed is offline
post #17 of 19 Old 08-07-11, 01:49 PM
mechman's Avatar
Steve Mechelke -mech
waleed wrote: View Post
So you went with the HC4000?
mechman is offline
post #18 of 19 Old 08-07-11, 09:33 PM
now am planning to get it ,one of my friend trying to convince me about benq w6000 .
so the question is, is it worth it to jump with price or there is projector in between
the different is 700.
Mr.mechman can u help plz
waleed is offline
post #19 of 19 Old 08-08-11, 10:49 AM
mechman's Avatar
mechman is offline
8350 , epson , hc4000 , mitsubishi
