| Home Theater Projectors How bright should a projector be?Discuss How bright should a projector be? in the Home Theater | Audio and Video forum; How bright should a projector be? On screen, how bright should a projector be? I believe I read one time that most commercial theaters are somewhere ... |
Views: 1745 - Replies: 7
| How bright should a projector be? On screen, how bright should a projector be? I believe I read one time that most commercial theaters are somewhere around the 15 foot-lamberts area of brightness. I've seen some reviews of home projectors that would measure around 6-7 foot-lamberts on a 100 inch screen. How important is this. I know that most direct view crt tvs are in the 25-45 foot-lambert range. So would this 6-7 be horribly dim even in a cave like dedicated home theater? | ||||
| | #2 | ||||
| Re: How bright should a projector be? I have lived with a dim 4-5ftL on an old lamp previously (AE700) but it was really too dim in hindsight The BenQ 8720 gave 9FtL in low lamp and was very punchy My JVC HD1 gives 12 on low mode and 15 on high - now that is great Next stage is to get a 1.3 gain screen to get over 16 which is where I understand is ideal Cheers Norpus | ||||
| | #3 | |||||
| Re: How bright should a projector be? Quote:
Hope my note helps. | |||||
| | #4 | ||||
| Re: How bright should a projector be? The more you have the more head room for light balance you have. You can actually be too bright aswell where you can cause eye strain. Plasmas and LCD can be like this if your field of view and light levels are not balanced. Try looking into a tourch close up, hurts doesnt it. For projection systems 12~15ftl is about where to aim for in dark conditions. With a little ambient light the reflective light level needs to get up towards 20fl to not lose infomation within the noise of the ambient light. Typically 6~12ftl is measured from a medium level calibrated projector. People can go wrong trying to go too big with there screens and sacrifice ftl doing so. What happens here once the bulbs get past 1000hrs they get to dim. Especially in ambient light. I use a AE900E, currently up to 1087hrs on the bulb, and I calibrated it last night and got 10ftl. I use a 70inch screen though, but this will allow me to get to 2000hrs. It is always a question of balance. Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #5 | ||||
| Re: How bright should a projector be? How do you calibrate it so you know the ftl? | ||||
| | #6 | ||||
| Re: How bright should a projector be? A radiospectrometer and the right software reports ftl as part of the outcome. You could also use a normal photo light meter. Bare in mind most cheap ones only use the Green channel as a sensor. Although in most cases still accurate enough. Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now? | ||||
| | #7 | ||||
| Re: How bright should a projector be? First of all you need to know how dark your room is gonna be while watching a movie. Then, what kind of projector are you looking for ? (dlp/LCD) ? Then comes the ANSI lumen rating of the projector. normally a 1000 ANSI lumen dlp projector is more than enough for a home theater application . From there you can decide which material screen you want to go for ? (matte white / glass beaded ) ??? Lot of work to do 1. Room size 2. Uncontrolled light 3. angle of viewing 4. projector mounting ? (ceiling/ table top / rear projection )? 5. type of screen ( retro-reflective / angular- reflective )? and so on.................... | ||||
| | #8 | ||||
| Re: How bright should a projector be? Foot-Lamberts is nothing but ANSI-lumen of the projector divided by square foot of the screen . So you have to decide on the screen size first and then choose a projector.. | ||||
