How to tell if a lamp is bad? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss How to tell if a lamp is bad? in the Home Theater | Audio and Video forum; How to tell if a lamp is bad? My basic question is: How can I really tell if a projector lamp is ready to be replaced? Does it ...
Discount Merchant
Old 10-15-07, 10:55 PM   #1 (Link)
New Member
Alias: loctones
Loc: Denver, CO
User: #8987
Since: May 2007
loctones is offline
My basic question is: How can I really tell if a projector lamp is ready to be replaced? Does it simply burn out, like a normal light bulb, or are there other failure modes?
Here's the longer version:
I bought an H31 about 20 months ago. I used it for just a little while before putting it into the closet while I finished my basement. A few months ago I brought it back out. At the 60 hour point, I started getting intermittent problems, where the projector would sometimes not power up--I would get a flashing orange "lamp" led. This supposedly meant that the lamp was bad, but I was surprised to be getting the problem with so few hours on the projector. Further, when the projector would power on, I could use it for hours. I tested use for up to 6 consecutive hours, and it NEVER shut off after successfully turning on.
So, I contacted Optoma and they had me send in the PJ for repair. They replaced the main board and the lamp driver, but told me that I needed a new lamp, as mine was going bad. I asked them if the lamp failure wasn't due to the bad lamp driver (perhaps over or under-driving the lamp, or not supplying stable power) and they told me that somehow they had determined that the failure was not due to the driver. I find this highly suspicious. In my experience a bad or unregulated power supply (which is what I'm assuming the lamp driver is) very often leads to component failure.
Anyway, now I have the projector installed again and I am getting the same problem. The PJ will intermittently turn on, and when it does turn on I can use it for hours at a time. For some reason, removing and re-seating the lamp allows the PJ to work properly almost all of the time.
So, how can I tell if the lamp is really bad? I assume that once it's bad it will just not power up at all. Is that correct? I'd like to educate myself a bit more on how exactly the lamp fails, so I have firmer ground to stand on when I call again and ask for a lamp replacement.
Old 10-16-07, 05:12 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: How to tell if a lamp is bad?
The only way that is even close to practical to know a lamp is bad is to test it on a known good supply in a known good set. That is, unless it is physically broken.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 10-16-07, 09:36 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
I'm wondering this myself. We have been using a Sanyo Z4 as our daily watcher for over a year now. I think I am noticing the light output going down, but I'm just not sure. Sometimes it competes with ambient light, sometimes not.
I almost want to get a light-meter so I can baseline it and know for sure.
Also, I hear the stories of failures after 100 hours and some that get 10,000 out of a bulb.
Old 10-16-07, 11:09 AM   #4 (Link)
New Member
Alias: loctones
Loc: Denver, CO
User: #8987
Since: May 2007
loctones is offline
lcaillo wrote: View Post
Well, the system just came back from being repaired, and it passed their "quality assurance" testing. I suppose I could assume that my PJ is good now, but I don't really have any way of being sure.
Is it unreasonable to assume that a bad lamp driver would cause premature lamp failure? They told me that they had determined that the lamp failure was not due to the bad driver, but I'm unsure of how they could actually do that.
Old 10-16-07, 07:18 PM   #5 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
I don't know how they could make that determination unless the lamp had reached the number of hours it was rated for.
-Joseph Joubert
Raise the bar.
Old 10-16-07, 10:19 PM   #6 (Link)
Alias: <^..^>SJ
Loc: New Zealand
<^..^>Smokey Joe's Avatar
User: #9850
Since: Jun 2007
<^..^>Smokey Joe is offline
I believe the bulb life actually should follow the half life curve, so when it is rated at 2000hrs it would in theory be half the light output.
These bulbs actually lack a little Red out of the block, and over time this effect appears to worsen. My bulb is at 1100 hours, I did a calibration on it last Saturday night and light output is a struggle, what I really noticed was how far Red was reduced in certain standard modes.
Visually I noticed faces heading a little green and or pink at times, so as the bulb ages I also think one needs to tickle the adjustments, colour/tint more often.
This aside, you I believe did the right thing to send it back. Here though what they did is weird, to change those components and not change the bulb aswell is weird if the problem still exists. Although they said, replace the bulb, so why not just do that in the process?
Although you dont mention warranty at all, so I presume you had to pay for the service, if so why again didnt they change the bulb? If it was a warranty job, it is a difficult position for the customer as you have to trust the service people.
What is and what isnt causal can lead to arguments, there I believe the right thing to do would be replace the bulb for customer satisfaction. Even if it wasnt casual, proof is hard to establish, where as satisfaction and return business is assured if the product is returned working.
At this point I would buy a bulb, if it fixes the issue, great, move on.
If the problem continues, return it to the service agent and take the value of the bulb off the bill. Since it was their statement that it would fix the problem.
Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now?
Old 10-19-07, 03:06 AM   #7 (Link)
Alias: kris
Loc: India
User: #5275
Since: Jan 2007
Rajesh is offline
I must have installed at least 25 optoma projectors this year. Most of them are home theater projectors.I had come across some problem in 3 projectors.
What i believe is the projector needs to be properly shut down. In India we face power failures , hence we use "UPS" ( uninterrupted power supply ). The projector lamp needs to cool down and that's why even when you switch off the projector with the remote, the fan keeps running even after switching off for 20-50 sec depending on the room temperature and the lamp heat . When ever you ceiling mount a projector make sure the air-conditioner is not too close. So that you don't cool the lamp and kick it on .
I prefer not to switch on the projector immediately after switching off , cause kicking on the lamp when it is too hot must be avoided.
Facts on lamp life:
Every manufacturer claims 2000/3000 hrs . The exact way to achieve is to avoid too many switch on's. Plan for a movie and switch on . If you are going to switch on and off a minimum 10 times a day ,Your lamp life might not even reach half its life.
Regards
Rajesh
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
Where to buy a DLP Lamp ???????? joey28 Video Displays and Processors 6 04-29-07 06:50 PM
How Long Does Your Projector Lamp Last? majorloser Home Theater Projectors 12 03-06-07 06:10 PM
Toshiba DLP Lamp Problems Roger Video Displays and Processors 0 05-31-06 01:36 AM
Optoma RD50 Lamp lcaillo Video Displays and Processors 0 05-28-06 11:22 PM
Mach 5 Audio
