Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Am I HDTV ready?
Discuss Am I HDTV ready? in the Home Theater | Audio and Video forum; Am I HDTV ready? Is my Sony VPH1272Q HD ready?...
Views: 406 - Replies: 1
Old 10-24-07, 07:20 AM   #1
New Member
Alias: hifi
Loc: tampa fl.
User: #11037
Since: Aug 2007
  hifidave is offline
Am I HDTV ready?
Old 10-24-07, 09:01 AM   #2
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Re: Am I HDTV ready?
I'm not familiar with that projector, but here's what I dug up:
http://www.broadcaststore.com/store/...l.cfm?id=13025
Looks like it will do 700 lines of horizontal resolution, so that's close to HDTV quality (720p is one of the standards).
The question is the inputs and how it sync's to the signal. It looks like it takes only an RGB input, which means you can only use video sources that output an analog signal (no HDMI or DVI)
then I found this:
http://www.curtpalme.com/forum/viewtopic.php?p=30700
Looks like some have had some real difficulty getting a signal from a satellite or tuner box to that projector due to the YCbCr input requirement (most HD sources output a YPrPb). Newer projectors can either sync to both, have a setting to make it work, or have another input option like HDMI to try.
So resolution-wise, it looks like that projector is good, but it seems like the implementation will be difficult.
Hopefully someone else will chime in. And I hate referring to other forums, but AVS seems to have some threads about this projector as well, so maybe somebody over there has had better luck.
Good luck and keep us posted!
Anthony
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
