| Home Theater Projectors Which budget LCD projector?Discuss Which budget LCD projector? in the Home Theater | Audio and Video forum; Which budget LCD projector? The Epson EMP-TW20 has got my attention so far - goes for about AU $1400, and has a decent CR ... |
Views: 653 - Replies: 5
| Which budget LCD projector? The Epson EMP-TW20 has got my attention so far - goes for about AU $1400, and has a decent CR of 1000:1. Is anyone familiar with it? This is what I'm looking for: * around the same budget as this one * LCD * 16:9 * CR at least 1000:1 if not better * reasonably quiet fan Can anyone make a recommendation? Not interested in DLP as I like to have movie nights with bro in law who can't watch DLP without getting a headache. | ||||
| | #2 | ||||
| Re: Which budget LCD projector? For the price you quoted you can easily get something better. You could look at a Sanyo Z4 it has at least a 1300:1 contrast ratio and should be able to find one used for below $1000. I am sure that there are others as well in this price range that would work just as well. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Which budget LCD projector? I have the Z4 and am a big fan. Low noise, good brightness and contrast ratio, VERY easy to set up with the lens shift and zoom. It was actually the only projector I was considering that could be all the way in the back of my room (19') and put up only a 92" screen size. Most of the others would have to be mounted much closer or project on a bigger screen (which wasn't an option). I paid around $1800 IIRC, over a year ago. Hopefully they are cheaper now. Good luck. | ||||
| | #4 | ||||
| Re: Which budget LCD projector? Check the used market. Often you can find low hour projectors for much less than new. Panasonic would be another one to consider. AE900U has 5500:1 and won many awards. The 700u is also great. I love mine. | ||||
| | #5 | ||||
| Re: Which budget LCD projector? Check Curt Palme - www.curtpalme.com The United States has become a place where entertainers and professional athletes are mistaken for people of importance.- — Robert Heinlein | ||||
| | #6 | ||||
| Re: Which budget LCD projector? My sister has the Panasonic AE900 and it cost ~$2500, similar to the Z4 and this is double the cost of the Epson! Not keen on second hand unless it's from someone I know and trust. I once bought an amp which failed after 2 weeks of use - never again. I've seen the Sanyo and Panasonic together and liked the AE900 for it's smoothness and colour. Seems hard to get any feedback on budget entry level projectors. | ||||
