Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Ax100u reliability?
Discuss Ax100u reliability? in the Home Theater | Audio and Video forum; Ax100u reliability? Hey all - I just purchased a REFURB Panasonic AX100U. I actually bought the refurb because it was 900 bucks, ...
Views: 602 - Replies: 5
Old 11-08-07, 12:12 AM   #1
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Ax100u reliability?
Hey all -
I just purchased a REFURB Panasonic AX100U. I actually bought the refurb because it was 900 bucks, which i thought was a screaming deal for this projector and still had the 90 day warranty. I did extensive research on this projector, and as you may or may not know, it reviewed exceptionally well.
So basically right after i hit the "commit to buy" button, i actually starting reading pages of reviews of people saying that it had major reliability problems. EEK!
It's a shame, BUT - i figured at this point that maybe i am actually better off with a refurb? This makes me think that whatever issues the projector DID have, were obviously found, fixed and released again. You'd almost think a refurb for this projector might be better than buying a new one? Hard to say for sure, but you'd think after this projector being out for so long, the issues would have been well documented enough and resolved in the refurbished ones.
I dunno - maybe my logic is over optimistic, but i just wanted to run this by some people with some knowledge in these projectors - i'm just looking for SOME reassurance other than my own optimism. THANKS!
Dale
Old 11-08-07, 12:14 AM   #2
Owner
Loc: L.A. (Lower Bama)
Re: Ax100u reliability?
This is how I generally view refurbished products. If refurbished by the manufacturer, they should be in top shape and any previous issues resolved. I would feel good about the purchase...
Old 11-08-07, 12:19 AM   #3
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Phew.. glad you have the same outlook - i typically stray away from refurb stuff, but my views all of a sudden changed when it helped my cause...
Old 11-08-07, 12:34 AM   #4
Exaneo
Inactive
Alias:
User: #
Posts: n/a
The plan is to run the crrrrrrap out of it for the first month or so - i'd like any issues that were to come about to happen within the 90 day warranty. I'd rather spend the money on a new lamp down the road than to have to fix the thing.
This is probably just like purchasing a car. Get one new and your chances you've bought one of the defective ones are slim, but are real. Get one of the good ones and you're in for years of hassle free ownership.
Buy one used (or hopefully refurb) and you'll know the history of the car. If it's good, it's likely it will continue to be good.
I dunno....
Old 11-09-07, 02:29 AM   #5
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
  Scuba Diver is offline
I feel the same way as Sonnie. I would think that if something went back to the manufacture to be refurbished, it is likely to come back with more than a polish. I'm sure you will be fine.
Now, with that said. Open boxed items that are not being sold as refurbished are a completely differnt ball game. Don't do it.
Old 11-09-07, 05:03 AM   #6
Exaneo
Inactive
Alias:
User: #
Posts: n/a
Gotcha.. yeah open box items scare me - and often times the price benefit isn't nearly worth it - at least from my experience, which is very limited.
Thanks for the reassurance though!
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
