Green Splotch - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Green Splotch
Discuss Green Splotch in the Home Theater | Audio and Video forum; Green Splotch Just got my refurbished Pan Ax100u in today... set it up for the first time and there was a green ...
Discount Merchant
Old 11-09-07, 08:36 PM   #1 (Link)
Alias: Dale Backus
Loc: Cary, NC
User: #13176
Since: Nov 2007
Exaneo is offline
Green Splotch
Just got my refurbished Pan Ax100u in today... set it up for the first time and there was a green splotch in the bottom right corner (when the projector is sitting right side up). It's a little unnerving, and being how i've been waiting SO long to finally get my first HD projector, and might have to send it in or something, i'm wondering if there is maybe something i can do?
I've heard of diagnositcs you can run to fix stuck pixels and stuff...
The green splotch is very faint and not very big... maybe 4 or 5 inches across on a 80" image. And it gets more noticeable the darker the screen gets. IE when i make the screen black, it shows up the best.
Any thoughts/remedies? I'm about to cry
Old 11-10-07, 01:35 AM   #2 (Link)
Bronze Supporter
Alias: FJ
Loc: Marysville, WA
User: #11951
Since: Sep 2007
Scuba Diver is offline
Re: Green Splotch
Wow, thats a bummer. I don't claim to know much about projector repairs. But I know a bunch about the sinking feeling you get in your gut when you spend a bunch money on something electronic and it does something like that. Sorry... I am sure there is someone wiser then I that might have a good answer for you.
I will search around and see if I can find anything. It sounds like the kind of thing that happens to a boob tube when a unshielded speaker is to close to the TV. Is that the kind of green splotch you see?
Old 11-10-07, 02:24 AM   #3 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is online now
Re: Green Splotch
I had a very similar green splotch problem with my Sharp LCD projector. They ended up replacing the optic block and it's been perfect since.
Definitely take care of it quickly and while it's under warranty.
Old 11-10-07, 01:08 PM   #4 (Link)
Alias: Dale Backus
Loc: Cary, NC
User: #13176
Since: Nov 2007
Exaneo is offline
Re: Green Splotch
Sigh... i bought this thing off eBay from "Proview Digital" i believe... who do i call about getting it fixed?
Them or Panasonic? I've never had to deal with something like this before.
Old 11-10-07, 01:11 PM   #5 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Re: Green Splotch
It might be as simple as a dust blob, which you can blow out with compressed air if you can find it along the light path. If it was pixels, it wouldn't really look like a splotch, more like a square. But you can always try and get it replaced, although they might just try and blow it out for you or ask you to try that first (maybe, since it requires opening the enclosure).
Old 11-11-07, 10:35 AM   #6 (Link)
Alias: Dale Backus
Loc: Cary, NC
User: #13176
Since: Nov 2007
Exaneo is offline
Re: Green Splotch
Very good idea... any idea if taking the cover off voids the warranty?
Old 11-12-07, 12:31 PM   #7 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Re: Green Splotch
I would guess it wouldn't void the warranty, since you need to open it to replace the bulb as part of normal operation anyway. They don't usually come with stickers that you have to break to open it. Now if you took apart the entire light engine...not sure. But I don't think the dust would be in there.
Old 11-12-07, 05:03 PM   #8 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Green Splotch
This is defiantly a dust blob, just blow some air in a can into the area around the LCD panels and that will get rid of it.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 11-14-07, 04:19 PM   #9 (Link)
Alias: <^..^>SJ
Loc: New Zealand
<^..^>Smokey Joe's Avatar
User: #9850
Since: Jun 2007
<^..^>Smokey Joe is offline
Re: Green Splotch
It may well be a dust blob, you also say "Refurbished", what was refurbished?, anywhooo I would still contact the company you purchased the projector from first for the very reason opening the box may indeed void the warranty or further claims if needed.
By contacting the company you cover yourself, log the date and time and any person you speak too or email. You will probably find they will advise service at a resgistered service agent(A bit of telephone book work might find a local brand specific service agent that you could suggest).
Use the warranty to your advantage whilst you still have it, thats what it is for anyway.
Light changes what it is doing depending if we are looking or not. Considering we only see this as a reflection of the past....what is it really doing now?
Old 11-14-07, 10:16 PM   #10 (Link)
Alias: Dale Backus
Loc: Cary, NC
User: #13176
Since: Nov 2007
Exaneo is offline
Re: Green Splotch
Good advice. That's probably what i'll do. It's just a pain to wait for the projector for so very long and then have to send it right back out and be without it for another week or two... sigh..
i may just take a can of air to it before. I definitely won't open it up besides the lamp cover..
Old 11-14-07, 11:07 PM   #11 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
Re: Green Splotch
<^..^>Smokey Joe wrote: View Post
I agree 100% with Smokey, exhaust your resources before trying to repair it yourself. If it is indeed a factory refurbished unit, I have some experience that may put you at ease.
My Sharp was a factory refurbished unit and originally was $3000. Of course I didn't pick it up for that price, I paid $600 including tax and shipping. It had a green 'blob', that's exactly how I described it. It was in the lower corner just in the letter box area. All in all it wasn't that big but since I just bought the projector I kind of expected a factory refurbished unit to be like new.
I called the place I bought it from and yes, they had me call Sharp, but confirmed it was under a refurbish warranty (one year) and said to call Sharp to get it looked at. Sharp had me take it to a local shop. The shop said the cost of repair was beyond what they were authorized to do. I start feeling like I was had, but another call to Sharp and they gave me an RMA number to send it to them. Then ended up replacing the optic block and $1500 worth of parts and sent it back to me. It now works flawlessly. Turn around time was surprising fast too, they had it a couple of weeks and it was back up on my ceiling.
So don't do anything that may void your warranty and do make sure to call the place you bought it from and the company that makes it. Worse case if you don't have a refurbish warranty, they usually can look up the unit serial number and confirm if it is a warranty item.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
mitsubishi hd 1080 red and green shadows kmacgrego Manufacturers Service and Support 50 06-12-08 06:25 PM
Ws-65315 Blinking Green Syndrome toneloc Manufacturers Service and Support 12 11-14-07 12:49 PM
Green Glue, RSIC, Both? Soundproofing in General Otto Home Theater Design and Construction 13 11-10-06 12:40 PM
Sharp Builds Super-Green LCD Factory Wayde Home Theater, Audio and Video News 0 09-22-06 08:30 PM
Greetings from the green hills of Yorkshire! Daddy Cool Welcome | Member Introduction 1 09-12-06 10:28 AM
Mach 5 Audio
