| Home Theater Projectors PT-AE2000U versus the PT-ax200UDiscuss PT-AE2000U versus the PT-ax200U in the Home Theater | Audio and Video forum; PT-AE2000U versus the PT-ax200U Tough Question:
Is the PT-AE2000 worth the extra $1,000?
I have heard the AX has a nive virtual 1080i and ... |
| | #1 (Link) | |||
| PT-AE2000U versus the PT-ax200U Tough Question: Is the PT-AE2000 worth the extra $1,000? I have heard the AX has a nive virtual 1080i and the AX has a 500 lumen advantage over the PT. This will allow me to use the room for playing cards or hosting a football party with the TV on in ambient light? Is this true or will the PT work just as fine in ambient light? | |||
| | #2 (Link) | ||||
| Re: PT-AE2000U versus the PT-ax200U That's a great question... Projector Central has done reviews on both of these units and both got rated and comments of being best in their class and price range. One thing to really take note of was PC said they had a tough time telling the difference between the ax200U and other native 1080p projectors. Quote:
Again, if you're looking at the cost factor, I don't think you can go wrong with the ax200U and by the time you're looking at a new bulb, 1080p projectors will be down even further in price and most likely better too. You won't get retail for the ax200U, but I'm sure someone would buy it off you and you could put that money towards a 1080p projector that will probably be under the $1500 mark by then. I know I was a bit wishy washy on that. I think you'd be happy with either. Just depends on your budget. $1000 can buy an awful lot of High Def movies though ![]() "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | ||||
| | #3 (Link) | |||
| | Re: PT-AE2000U versus the PT-ax200U I'd say that's tough call... since quite a few people say that they cannot tell the difference between 1080i/720p and 1080p. I could tell a difference between my old Z4 and the PT-AE2000U, but there are many other factors other than resolution that have to be considered. Contrast, brightness, color and sharpness were all improved considerably. | |||
| | #6 (Link) | |||
| Re: PT-AE2000U versus the PT-ax200U I'll be pulling the trigger tomorrow. I've researched, called, and narrowed the list down, then ended up adding to it again, and narrowing that list down... I'm getting the Panasonic AX200u. For my room setting it has the lumens, plus I have an existing setup with the ceiling mount already in place for my current projector, cable raceway is already run, and the screen is a permanant fixture on the wall. So I have to have a projector that I know can be adjusted to match the current screen position without moving anything. Then I ran into the issue that a few projectors only accepted a max of 1080i. Normally not a big deal, but I have a multifunction 'Theater room' that also has a 55" 1080p HDTV. I have no plans to change my player's output mode when I switch between devices. Also the AX200's ability to accept 1080p/24 input signals was nice too. For me, it was the one projector that met all the requirements. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #8 (Link) | ||||
| Re: PT-AE2000U versus the PT-ax200U Quote:
How's your new projector? Enjoyable? How much improvement compared to your XVGA projector? What about your screen? If I remember well, your old projector was a 4:3 aspect ratio one... Looking forward to hear from you! ![]() Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #10 (Link) | |||
| Re: PT-AE2000U versus the PT-ax200U Just purchased the PT-AX200U and coupled it with a Wilsonart FG DIY screen. WOW!!! This is a great combo. The picture exceeded my expectations. Just as good if not better than some of the high-end PJ I saw at the specialty stores. | |||
| Thread Tools | |
Similar Threads | ||||
| Panasonic PT-AE2000U 1080p HD Projector | Sonnie | Home Theater Projectors | 47 | 05-30-08 03:50 PM |
| LCD versus Plasma versus DLP | trgovic | Video Displays and Processors | 21 | 02-14-08 07:41 AM |
| Battle of the Ultras: SVS PC-U Old Versus New | tweakophyte | SVSound | 18 | 01-17-08 07:57 PM |
| Assymetry versus on-axis? | John Simpson | Home Theater Design and Construction | 6 | 08-06-07 10:52 PM |
| McIntosh MC-275 Mk IV versus MC-250 | rcarlton | HiFi Audio Components | 5 | 07-15-07 12:43 PM |
