HDMI issues with Infocus IN76 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss HDMI issues with Infocus IN76 in the Home Theater | Audio and Video forum; HDMI issues with Infocus IN76 I have a problem with my Infocus IN76 projector not seeing any signal sent to it via HDMI. Initially I ...
Discount Merchant
Old 05-10-08, 11:50 AM   #1 (Link)
New Member
Alias: bbop
Loc: England
User: #20592
Since: May 2008
  sandman01244 is offline
Unhappy HDMI issues with Infocus IN76
I have a problem with my Infocus IN76 projector not seeing any signal sent to it via HDMI. Initially I had the projector hooked up to a PS3 directly via HDMI and had no problems. I have just purchased the new Onkyo 606 amp however, so instead of the HDMI connection going directly to the projector it now passes through the amp. This is where the problems began! With this set up I was getting no signal through to the projector. Thinking the amp was to blame I went back to the original configuration of the PS3 connected directly to the projector and to my suprise I still obtained no signal. When HDMI is selected the screen goes black for a minute before returning to the red Infocus start up screen. I have tried all the possible resets on the PS3 and used a number of different HDMI cables but I still get no picture. The projector is still working fine via the component imputs!
Please help before I pull all my hair out!!!!
Old 05-10-08, 12:10 PM   #2 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
  Blaser is offline
Re: HDMI issues with Infocus IN76
Welcome to the shack Bob!
I am so sorry to read about your projector HDMI issue. You know that you should first turn it on and then the PS3, otherwise there might be some handshake issues. Re-Check the HDMI output IS enabled on the PS3. Re-do the PS3 setup and check again for one last time. Let the receiver out of the loop for now.
If you still have issues, your unit might need servicing...
Let us know what you find after making sure PS3 is putting out through HDMI.... And don't pull your hair out, it may be only a small issue that could be easily solved or repaired
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 05-10-08, 04:05 PM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
  Blaser is offline
So Bob, did it work?
ASME AI
Old 05-10-08, 08:40 PM   #4 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
  Rambo4 is offline
Hey Bob, I am also the owner of an IN76, and had the same issue with my Sony DVD upconverting player. For the life of me I could not get the HDMI to do the handshake. Thats when I found this little tidbit in their manual...
HDMI DDC: turns the EDID extension on and off. Some graphic cards
cannot recognize the projector’s EDID. By default, the HDMI EDID
extension is on (checkbox is checked) and the M1-DA EDID extension
is off (checkbox unchecked). Change these settings if you have trouble
using HDMI or DVI sources.
You'll find it in the menu under Service - HDMI DDC. I had to turn mine off to get things working. Hope this helps, and buy their extended warranty! I had my projector for a year and eleven months when it died on me two weeks ago. There is a fuse problem with that projector, so just a head's up. Simple fix under warranty, but likely expensive if not. I just got in under the wire, and I am purchasing the extended warranty shortly.
Old 05-11-08, 11:56 AM   #5 (Link)
New Member
Alias: bbop
Loc: England
User: #20592
Since: May 2008
Thanks guys for all your help. Unfortunatly I am still having no joy. It looks like I will have to ship it back to Infocus for a service. I will post when I find out the problem.
Old 05-11-08, 12:01 PM   #6 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
I had some handshake issues with another PJ and I had to unplug the HDMI from the back of the amp and plug it back in after everything else was powered up. It is a pain but it might work for you system the same way.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
infocus litepro 220 ford10000 Infocus 2 06-25-08 01:09 AM
InFocus lcaillo Manufacturer and Vendor Reference Information 0 05-14-07 08:36 PM
HDMI Twins: Is BetterCables Selling an $89 HDMI Switcher for $350? geekwithfamily Home Theater, Audio and Video News 2 02-27-07 12:11 PM
Infocus 16 X 9 screen today only $30 chasw98 Projector Screens | DIY Screens 0 09-22-06 05:28 AM
InFocus IN76 Video Projector Review Wayde Home Theater, Audio and Video News 0 08-14-06 03:50 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
