| Home Theater Projectors Best projector for Sports Bars?Discuss Best projector for Sports Bars? in the Home Theater | Audio and Video forum; Best projector for Sports Bars? Hi Guys.
I'm not a HT expert by any means, I know if I wanted a projector for my home ... |
| | #1 (Link) | |||
| Best projector for Sports Bars? Hi Guys. I'm not a HT expert by any means, I know if I wanted a projector for my home theatre I'd go with the Epson 1080p, but that's dark, ideal conditions.. So here's the question. I own a Sports Bar in Houston, and I want to be known as a "high tech" sports bar. One of the keys is servin' up the games in HDTV. Which projectors would you suggest, disregarding budget for the time being? Good bulb life (although I hear you can get the $400 warranties on a lot of them to replace the bulb), good image under higher than ideal lighting conditions, and at least 80-100" screen. Whichever projector I choose I'll have two of them, and then a number of more basic HDTV LCDs be installed into the bar in the upcoming weeks.. What projector would "awe" you if you were to walk into a sports bar? Is there a projector that you'd go to a bar specifically to watch the game on that screen? Love to hear all the suggestions. | |||
| | #2 (Link) | |||
| Re: Best projector for Sports Bars? First of all welcome to The Shack, Seeing as money is not an issue right now then getting a commercial/industrial projector would be far better for you. They run in the $15,000 to $30,000 range some of the better ones still use CRT technology and thus don't require bulb replacement and also support more than one native resolution . The contrast on these are very high and last far longer than LCD or DLP projectors. The only downfall is they are larger than LCD or DLP units. In your case I would not recommend going with any of the consumer grade units as they will not handle being on for hours on end as bulb life is still not going to last you more than about half a year at best in your situation. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | |||
| | #3 (Link) | |||
| Re: Best projector for Sports Bars? Our church has one of those Dell LCP / MP models. It seems to do great and from what I know.. cheap in price. Just make sure you have couple of back-up of lamps . Good luck w/ the sports bar. Free beer for our posts? ![]() | |||
| | #4 (Link) | |||
| Re: Best projector for Sports Bars? For a sports bar brightness aka lumens is probably more important than CR. Most high lumen projectors are still 4:3 but there are some very bright 720p projectors out now too, which would be great for sports. One thing to consider is the screen. You'll want something that performs well with ambient lighting, especially Sunday afternoons. HoloDisplays has a great ambient light screen called the HoloVega. I have their full price list, so if you tell me the size I can tell you what they it would cost. Tomorrow I'll look up some high lumen PJs for you too, there are some at some good prices that you can get. For your setup you need bright and vivid in a variety of viewing conditions and that is definitely doable. "Make everything as simple as possible, but no simpler." - Albert Einstein "If all else fails, spin the cat."- Grzboken | |||
| | #5 (Link) | ||||
| Re: Best projector for Sports Bars? Quote:
Leonard "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | ||||
| | #7 (Link) | |||
| Re: Best projector for Sports Bars? Take a look at the Optoma EP1691. It's a widescreen dlp, 2500 lumens, is very small. Because it is black and very small, it almost disaapears into a dark ceiling and will hide well and not be a distraction. Most reputable places have it for less than a $1,000.00 which is even better! At that price it is well worth a look. | |||
| Thread Tools | |
Similar Threads | ||||
| new projector | jwhite8086 | Home Theater Projectors | 4 | 12-09-07 02:20 PM |
| New to HT : Which Projector | aod | Home Theater Projectors | 17 | 12-03-07 05:36 PM |
| Trip-Lite power bars | tonyvdb | Remotes | Cables | Accessories | 4 | 11-30-07 09:47 AM |
| Best projector for watching sports? | jhanseling | Home Theater Projectors | 6 | 11-18-07 04:36 PM |
| Do you use shorting bars? | jwhite8086 | Home Audio Speakers | 1 | 05-10-07 11:56 AM |
