Best projector for Sports Bars? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Discuss Best projector for Sports Bars? in the Home Theater | Audio and Video forum; Best projector for Sports Bars? Hi Guys. I'm not a HT expert by any means, I know if I wanted a projector for my home ...
Discount Merchant
Old 01-07-08, 06:22 PM   #1 (Link)
New Member
Alias: Nick
User: #15226
Since: Jan 2008
snickn is offline
Hi Guys.
I'm not a HT expert by any means, I know if I wanted a projector for my home theatre I'd go with the Epson 1080p, but that's dark, ideal conditions..
So here's the question.
I own a Sports Bar in Houston, and I want to be known as a "high tech" sports bar. One of the keys is servin' up the games in HDTV.
Which projectors would you suggest, disregarding budget for the time being?
Good bulb life (although I hear you can get the $400 warranties on a lot of them to replace the bulb), good image under higher than ideal lighting conditions, and at least 80-100" screen.
Whichever projector I choose I'll have two of them, and then a number of more basic HDTV LCDs be installed into the bar in the upcoming weeks..
What projector would "awe" you if you were to walk into a sports bar? Is there a projector that you'd go to a bar specifically to watch the game on that screen?
Love to hear all the suggestions.
Old 01-07-08, 06:42 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Best projector for Sports Bars?
First of all welcome to The Shack,
Seeing as money is not an issue right now then getting a commercial/industrial projector would be far better for you. They run in the $15,000 to $30,000 range some of the better ones still use CRT technology and thus don't require bulb replacement and also support more than one native resolution . The contrast on these are very high and last far longer than LCD or DLP projectors. The only downfall is they are larger than LCD or DLP units.
In your case I would not recommend going with any of the consumer grade units as they will not handle being on for hours on end as bulb life is still not going to last you more than about half a year at best in your situation.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2 HD DVD & Samsung BDP1400 BluRay players, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
Old 01-11-08, 11:26 PM   #3 (Link)
Alias: Mike
Loc: Austin
User: #14610
Since: Dec 2007
Picture_Shooter is offline
Our church has one of those Dell LCP / MP models. It seems to do great and from what I know.. cheap in price. Just make sure you have couple of back-up of lamps . Good luck w/ the sports bar. Free beer for our posts?
Old 01-11-08, 11:34 PM   #4 (Link)
Alias: Bill
Loc: Upper State NY
wbassett's Avatar
User: #6427
wbassett is offline
For a sports bar brightness aka lumens is probably more important than CR. Most high lumen projectors are still 4:3 but there are some very bright 720p projectors out now too, which would be great for sports. One thing to consider is the screen. You'll want something that performs well with ambient lighting, especially Sunday afternoons.
HoloDisplays has a great ambient light screen called the HoloVega. I have their full price list, so if you tell me the size I can tell you what they it would cost.
Tomorrow I'll look up some high lumen PJs for you too, there are some at some good prices that you can get. For your setup you need bright and vivid in a variety of viewing conditions and that is definitely doable.
Old 01-11-08, 11:37 PM   #5 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
tonyvdb wrote: View Post
CRTs last longer than LCD and DLP? Really? Where do you get that? I would not recommend LCD because of the likelihood of buildup of crud in the light path that can damage filters, but DLP is pretty reliable in this kind of environment. Unlike CRTs which age rather fast at high contrast ratios, DLP will look nearly like new with a new lamp. CRT sets require significantly more calibration and more maintenence.
Leonard
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 01-12-08, 12:26 AM   #6 (Link)
Alias: Mike
Loc: Austin
User: #14610
Since: Dec 2007
@ hooters , couple of LCD and Plasma's seem to work well. lol
Old 01-12-08, 10:51 AM   #7 (Link)
Alias: John
Loc: US - midatlantic
User: #3960
Since: Nov 2006
solarscreen is offline
Take a look at the Optoma EP1691. It's a widescreen dlp, 2500 lumens, is very small. Because it is black and very small, it almost disaapears into a dark ceiling and will hide well and not be a distraction. Most reputable places have it for less than a $1,000.00 which is even better! At that price it is well worth a look.
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
Similar Threads
new projector jwhite8086 Home Theater Projectors 4 12-09-07 02:20 PM
New to HT : Which Projector aod Home Theater Projectors 17 12-03-07 05:36 PM
Trip-Lite power bars tonyvdb Remotes | Cables | Accessories 4 11-30-07 09:47 AM
Best projector for watching sports? jhanseling Home Theater Projectors 6 11-18-07 04:36 PM
Do you use shorting bars? jwhite8086 Home Audio Speakers 1 05-10-07 11:56 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
