Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Home Theater Projectors
Why are projector lamps so expensive and is there a DIY solution?
Discuss Why are projector lamps so expensive and is there a DIY solution? in the Home Theater | Audio and Video forum; Why are projector lamps so expensive and is there a DIY solution? I just ordered a spare lamp assembly for my IN72 at a cost of $340, which is actually a deal ...
Views: 3224 - Replies: 9
Old 01-31-08, 11:52 PM   #1
Alias: Ben
Loc: Rome, NY
User: #16202
Since: Jan 2008
  BenJF3 is offline
I just ordered a spare lamp assembly for my IN72 at a cost of $340, which is actually a deal compared to the standard cost of $399. My original lamp has about 2700 hours on it and with a life expectancy of 3000 I though it would be wise to be ready for the inevitable granted that some owners have reported going well beyond 3000. Thus the query of why are lamps so expensive? One would think by now that manufacturers have streamlined the process.
This also leads to my next point. I read that some people had sources that could provide the actual bulb at a fraction of the cost of a new lamp. I believe it was around $150. This seemed like a viable option for anyone who wanted to take apart the existing lamp assembly and repair it, but it really has not been explored in depth.
I realize that Samsung is already making rear projection sets with LED lamp engines that are said to be good in excess of 10000 hour which means others will follow suit and I expect it to reach front projection as well. I was just wondering if anyone wanted to weigh in on this?
I mean I could go with an LCD or Plasma, but you can't find one that will give a screen above 65" without getting into the ten thousand dollar range. Also, I like the feel of the front projection because it makes you seem like you are in the theater.
Old 02-01-08, 07:18 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Why are projector lamps so expensive and is there a DIY solution?
The DIY solution is to find the original lamp from the least expensive supplier, usually without the cage. There are several places to find cross reference info and more vendors are supplying the lamps all the time. Some can be found, some cannot without going to the maker of the display.
Try some of the vendors here:
http://www.hometheatershack.com/foru...tributors.html
another to check
http://www.intl-lighttech.com/tvlamps
Just be sure that you are getting the same lamp, not a sub or replacement made by a different vendor, unless you can confirm compatability with no doubt.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 02-01-08, 07:36 AM   #3
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
  Rambo4 is offline
Hi, I will soon be running into the same issue with my IN76, and I'll do a bit of searching myself in this regard. I'll be interested in anything you can find out as well.
On a side note, the Infocus products are great for having an absolutely unknown port on the back called an M1-DA. I love the blank stares I get from the Geek Squad at Best Buy trying to find a cable. Anyhow, as a Infocus projector owner I thought you would feel my pain.
Good luck on the lamp search.
Old 02-01-08, 07:40 AM   #4
Alias: Ben
Loc: Rome, NY
User: #16202
Since: Jan 2008
  BenJF3 is offline
Well, the lamp for the IN76 is the same as the IN72. I mean, I'm good at taking things apart and putting them back together, so I'd definitely give it a go. I will save the assembly to my original lamp once it goes dead and try to find further information.
Old 03-24-08, 05:41 PM   #5
Alias: Zip
MatrixDweller's Avatar
Loc: Canada
User: #10408
Since: Jul 2007
  MatrixDweller is offline
I wouldn't recommend DIYing a projector replacement bulb. Projector lamps are usually under extremely high pressure so be extra careful handling one that doesn't have a cage on it. If it were to explode (old one or new) it could send glass and metal fragments everywhere (wear safety glasses ). The gasses inside the bulb wouldn't be too healthy for you either (mercury). Failing to get the right bulb and assemble it correctly could cause it to explode within the projector also, which wouldn't be good. There is a reason why they are so expensive (other than corporate greed).
Old 03-24-08, 06:24 PM   #6
lcaillo's Avatar
User: #328
  lcaillo is offline
While caution is prudent, these are not so hard to handle. The main thing is to be sure not to get any oils or debris on the glass and to make sure the fit is correct. Make sure that the lamp is the OEM lamp. People change the lamps all the time, with no problems.
Old 03-24-08, 07:17 PM   #7
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
I wouldn't DIY an FP replacement bulb as well, but some people have the necessary skills and knowledge, otherwise I wouldn't recommend so.
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 03-24-08, 07:35 PM   #8
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
  superchad is offline
Bulbs are pricey because the market is still small compared to others so they need to generate income somehow.......just good business.
Old 03-24-08, 08:22 PM   #9
lcaillo's Avatar
User: #328
  lcaillo is offline
The main reason that the lamps are so expensive is the precision with which they have to be made to get the right mix of light output and color spectrum, while lasting thousands of hours at relatively high output.
While I would not recommend just anyone swap lamps, there really is not much to it. The level of DIY skill at HTS is pretty high and most members here wold have no problem with the process. You handle mercury containing flourescent tubes which are more likely to break and have more in them than a projector lamp. Far more dangerous. The big risk in changing a lamp is contaminants that cook from the heat causing early failure. Just wear some gloves and it is not a big deal. What is a big deal is buying the right lamp. Many more people create problems for themselves by buying replacement lamps that are not actually OEM lamps than have problems swapping them in the housing.
Old 03-25-08, 07:06 AM   #10
Alias: Ben
Loc: Rome, NY
User: #16202
Since: Jan 2008
  BenJF3 is offline
Agreed on many points. That's why I wanted to find a DIY solution. I was an electronics technician for many years and would take on the task, the problem is finding an OEM replacement bulb. In my case, I need an IN72 bulb. I'd give it a go.
The next logical question is when will we see LED based lamps for front projectors?
« Home Theater Shack > Home Theater | Audio and Video > Home Theater Projectors »
